Page 3 of 3 1 2 3
Re: New disc brake conversion doesn't work [Re: Sixpak] #58231
05/25/08 02:14 AM
05/25/08 02:14 AM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
I have manual discs using spindles and discs from a 73 plymouth and a proportioning valve from a manual disc brake dart sport from the early 70's. manual discs and they work great.
Re: New disc brake conversion doesn't work [Re: Joshs68] #58232
06/22/08 09:50 PM
06/22/08 09:50 PM
Franksville, WI
g-man70 Offline
g-man70  Offline
Franksville, WI
Hey timinator, any updates? Did you get this issue resolved? I just did the same conversion on my 68 Charger and have the exact same problem. Wondering if more aggresive brake pads made a difference.
Re: New disc brake conversion doesn't work [Re: g-man70] #58233
10/24/14 11:21 PM
10/24/14 11:21 PM
Toronto, Ontario, Canada
plazomat Offline
plazomat  Offline
An old thread but I seem to have a similar problem - did the discotech conversion using
10.87 rotors
72 Ebody calipers
1 1/32 master
all new lines and hoses
No proportioning valve at all....
10*1.75 drums out back of a 69 Plymouth Belvedere.
Not a super firm pedal, car stops but can't lock up anything, felt better with the manual drums!
Where should I start?
Plazomat
Re: New disc brake conversion doesn't work [Re: plazomat] #58234
10/25/14 02:16 AM
10/25/14 02:16 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
15/16" master cylinder. Then you will likely need an adjustable proportioning valve or a factory B body one off a disc brake car.
Kevin
Re: New disc brake conversion doesn't work [Re: Twostick] #58235
10/25/14 12:21 PM
10/25/14 12:21 PM
Central TX
roe Offline
roe  Offline
Central TX
I hope I don't come across wrong but I've read many threads with this complaint. Why do so many people ignore these bad results threads and spring for the aftermarket stuff? There are also many folks that use the factory Mopar parts to adapt their cars and have great results. And a lot of that stuff is available in junkyards and local parts stores. I don't get it.
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: New disc brake conversion doesn't work [Re: roe] #58236
10/25/14 08:12 PM
10/25/14 08:12 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I call it the "O, Shiny!" effect.
Don't be the exception.
Page 3 of 3 1 2 3
