Re: Which Ballast Resistor for Electronic Ignition?
[Re: dsgtx]
#580481
01/12/10 08:55 PM
01/12/10 08:55 PM
RapidRobert
In order; take all wires off of the item being checked (for resistance). Ohmmeter on "ohms". touch ohmmeter leads together & adj the meter if it has a "zero adjust" (old analog types). Touch leads to each end of the part. No problem mixing/matching ballasts between points/elec just if the ohms is too low for the coil used it'll burn it out eventually. I have an oe (points) 2 terminal ballast on a stock elec ign (measured @ 1.7 ohms)& works good but I am leaving power on the table using that high of ohms. The ballast listed for the chrome or orange boxes iirc is 1.25 ohms and the race one 2444641 (.25) ohms. using the one (run) side of a later 4 terminal ballast is listed at a nominal .5 ohms (one I checked has 1.4 ohms) and wiring both sides of it together in parallel gives 1.1 ohms which would be perfect. A decreasing ohms value resistor will give you a hotter spark/more power but at the expense of shorter coil life.
[Re: dsgtx]
#580483
01/12/10 09:31 PM
01/12/10 09:31 PM
Posts: 11,632 SHELBY TWP,,MICHIGAN
72N96RR
I LOVE WEDGIES
I LOVE WEDGIES
Check DINTY68RR here on Moparts...4 prong resistors NOS CHEAP!!!!!!!
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free.. If they come back it means nobody else wanted them either..!!
[Re: dsgtx]
#580484
01/12/10 09:32 PM
01/12/10 09:32 PM
RapidRobert
Hey your welcome and correct they are not polarized
