Re: Scat Kit Bearing and Balance Quality
[Re: 69Cuda340S]
#57884
05/07/08 08:44 PM
05/07/08 08:44 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
It is always a good idea to have someone check any machining or balancing work. You have saved a bunch of money already by going to this kit, may as well use some of the saved money to check the work that was done.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: 69Cuda340S]
#57885
05/07/08 11:06 PM
05/07/08 11:06 PM
Posts: 2,587 missouri, USA
moparmojo
missouri, USA
Well I guess, I might want to fully explain the issue with your intended machine shop. Get their direct rationale for why extra money is needed from you when the kit is supposed to be balanced already. I would also ask that if it is within tolerance that your machine eat the cost to double check, or if he is unwilling to do that, then I would suggest you advise him you would expect that if you do pay him to balance and go over they you make the tolerances even more exact. If you are stuck paying for it, you might as well get an even better product out of it in the end. So if the initial quality turns out good, and the machinist still requires additional work, then I would set expectations high for what you want in return.
