Re: Pictures of Dakota drag trucks please. ALL years.
[Re: ram87]
#578788
01/12/10 06:44 PM
01/12/10 06:44 PM
Posts: 364 Kentucky
sc301v
Kentucky
Once was and I would like for it to be again but probably won't happen with me. I have most of the parts to put it together. Just don't have the know how.
Wanta sell it ??
[Re: sc301v]
#578789
01/12/10 07:17 PM
01/12/10 07:17 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
here's mine...although it's more of a street truck.
mild 383 stroker build, managed to squeek out a 505hp on the engine dyno, but realistically it's probably making 475-480 at the crank as it sits inside the truck, and likely only putting 400-ish to the ground.
truck weighs 4200 lbs with me in it.
pretty slow too. 13.9 ET @ 103 MPH. if I get it to hook, it should be low 13s, and if I'm lucky, high 12s.
full street trim, full interior, all stock sheet metal, stock suspension, with hotchkis 2" drop coil springs and 3" drop leaf springs.
4.56 gear'd Detriot true trac in a 9.25" axle, and a TKO-600 5 spd with .64OD make it fun to play with, and still cruise the freeway at leisurely RPMs
**Photobucket sucks**
[Re: 8secDart]
#578795
09/17/13 06:07 PM
09/17/13 06:07 PM
Posts: 3,414 Toronto
mshred
Toronto
Here is a couple I'am working on.The black one is a 95.The blue one is a 94.I have an 8 3/4 for sale.It is a bolt in if someone can use it.Lenny
That last blue one looks awesome! Any details on it?
[Re: mshred]
#578796
09/17/13 06:59 PM
09/17/13 06:59 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
Not a Dakota but a Dodge D-50. Leaf springs, home made Caltracs, 315/60 M/T Drag Radials,2950 lbs. 394 small block, pump gas on motor only, so far. 1.34 60 ft.,6.34 @ 109 1/8 mile. Looking for some 6.20's in the up coming good air.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: julian2007]
#578802
09/18/13 02:33 PM
09/18/13 02:33 PM
Posts: 2,496 PA
moparacer
PA
My 88 Dakota from the 90's
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: ]
#578806
08/28/14 11:39 AM
08/28/14 11:39 AM
Posts: 25 Ohio
Dakotamecrazy
Ohio
If you are still on here could you please tell me where or who made that hood? I am looking for something just like that. Thank Chris I was asking about 1969HEMI's pic. I will try to send a message.
[Re: Dakotamecrazy]
#578807
08/28/14 03:55 PM
08/28/14 03:55 PM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
My 88 with 5.7 Hemi/727 installed. Gonna add a 93 front clip for better looks and more room. Hope to have it going this spring.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
