Re: Biggest street tire under a 1969 B-Body???
[Re: MIKES_DUSTER]
#578627
06/25/10 01:05 PM
06/25/10 01:05 PM
Posts: 130 Marcell, MN
68 Roadrunner
Marcell, MN
Getting ready to order a set of tires and wheels. Anyone think a 275/60R15 BFG Drag Radial is going to look too small on a 10" rim?
1968 Roadrunner 383 auto
.060 KB 400 domed pistons, Stealth heads, Torker intake, Holley 830, Lunati Voodoo cam 276/284, .513/.533, TCI 3500, 3.91 gears, all ARP fasteners,
[Re: Labratt]
#578630
06/25/10 02:59 PM
06/25/10 02:59 PM
68 Roadrunner
Marcell, MN
In my opinion,they will look too small! I tried out a set of p275-60's a while back,and HATED the look! I'm with Doctor Doug! P295/65R-15'S! Look just right! RandyB
That's what I was afraid of. I have 275/60R15 street tires on it now with 15x8 wheels. My car sits low and they look ok. But on the 10" wheels they might look funny. What kind of tire are you guys running in a 295/65R15? I want some type of a D.O.T slick / street tire. It does not hook up at all on the street tires. I would like to take it to the track for street tire night, but it has to have DOT tires.
[Re: Mr.Yuck]
#578632
06/25/10 04:11 PM
06/25/10 04:11 PM
68 Roadrunner
Marcell, MN
I think I am going to order 15x10 Jegs Sport Mag II with 4.5" back spacing and 295/55R15 Mickey Thompson ET street radial. Hopefully they fit under the old Roadrunner!!!
[Re: 68 Roadrunner]
#578633
06/25/10 04:15 PM
06/25/10 04:15 PM
68 Roadrunner
Marcell, MN
I didn't want to run the 295/65 because they are taller than I want.
[Re: pro6pakRR]
#578635
06/26/10 05:33 PM
06/26/10 05:33 PM
Posts: 284 Louisiana
kzinge1
Louisiana
69 RR, 295/65 15 M/T E/T Streets 15x8" wheels 4.5" BS, SS springs 8 3/4 rear stock location IMHO this is the biggest combo that will safely go under a 69 Plymouth. It's perfectly centered in the wheel wells, doesn't rub and looks perfect.
[Re: kzinge1]
#578636
06/26/10 10:32 PM
06/26/10 10:32 PM
68 Roadrunner
Marcell, MN
That's like a 30" tall tire! I don't want to go taller than 28"...but I want as wide as I can go. I'm going to order the 295/55R15 on 15x10 Monday. I'll let you know if they fit.
[Re: 68 Roadrunner]
#578637
06/26/10 10:59 PM
06/26/10 10:59 PM
Posts: 237 Whitinsville Ma
superbee500
Whitinsville Ma
I just put a set of 295 55 15s on my bee with a 8" inch rim . Fit nice ill post pics in the morning. Kevin
69 superbee
04 ram 3500
[Re: superbee500]
#578638
06/26/10 11:01 PM
06/26/10 11:01 PM
68 Roadrunner
Marcell, MN
Cool! I can't wait to see the pics! Do you think they would fit the car with a 10" wheel? How do the 295's fit the 8" wheel?
[Re: kzinge1]
#578640
06/27/10 08:08 AM
06/27/10 08:08 AM
68 Roadrunner
Marcell, MN
Ok. Thanks. I'm going to do some measuring today and see what I come up with.
[Re: gtx69]
#578643
06/27/10 07:22 PM
06/27/10 07:22 PM
Posts: 17,836 S.E. Michigan
ZIPPY
S.E. Michigan
Most bigger tires will probably rub the leaf spring with 5.5" backspace. Something between 4 and 5 inches is usually needed. At least mine is that way.
Rich H.
Esse Quam Videri
[Re: PC-CHARGER]
#578646
06/27/10 08:10 PM
06/27/10 08:10 PM
Posts: 324 N.H.
mopar-addiction
N.H.
I'm running steelies 15x10 w/5.5" back spacing with 295-50-15's with out any rubbing on my 68 RR.
[Re: mopar-addiction]
#578647
06/27/10 08:49 PM
06/27/10 08:49 PM
68 Roadrunner
Marcell, MN
That looks awesome! 5.5" back spacing? Seems like most guys are running 4.5". Would your set up fit with 4.5" BS? Just wondering before I order rims.
[Re: 76Swinger]
#578649
06/27/10 09:00 PM
06/27/10 09:00 PM
68 Roadrunner
Marcell, MN
325/50/15 M/T drag radials, 15x10 with 5.5"BS. Had to do some rolling on the inner and outer wheel house lips
Holy crap...that is a huge tire! Man that looks sweet!
#578652
06/27/10 10:16 PM
06/27/10 10:16 PM
68 Roadrunner
Marcell, MN
Here's a link to another thread about the same subject which contains more pictures to help you. https://board.moparts.org/ubbthreads/show...rue#Post5237205
Thanks!!!!!!!
[Re: 68 Roadrunner]
#578653
08/05/10 12:13 AM
08/05/10 12:13 AM
68 Roadrunner
Marcell, MN
I bought 15x10's with 4.5" back spacing with 275/60/15 ET Street Radials and I had to trim the wheel well lip off and roll it over so they didn't rub.
[Re: 5126brl No more]
#578656
09/21/10 11:13 PM
09/21/10 11:13 PM
Posts: 683 Northern NJ
68 Sat
Northern NJ
thanks to this post I have mynew meat. 295/55/15s on 5.5 inch back spaced steelies.,..
1963 Chrysler 300 Pace Setter Convertible 21K mile survivor
1969 Dodge Coronet 500
1956 Desoto Hemi
1955 Chrysler C300
[Re: 68 Sat]
#578659
09/22/10 08:16 PM
09/22/10 08:16 PM
Posts: 1,212 QLD Australia
Keith Black®
QLD Australia
345/30 x 19 Michelin Pilot PS2 Unlawful rear end setup
-------------------------------- Darren Beale Keith Black Racing Engines®
[Re: Keith Black®]
#578661
09/22/10 09:00 PM
09/22/10 09:00 PM
Keith Black®
QLD Australia
and another showing width/room
[Re: Keith Black®]
#578662
09/24/10 10:45 PM
09/24/10 10:45 PM
Keith Black®
QLD Australia
not much clearance...but enough..
[Re: Keith Black®]
#578663
09/24/10 11:55 PM
09/24/10 11:55 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
315/45-17 on a 17x11 with 6" B/S
BTW that translates to a 12.5" wide 28 1/4" tall tire & there is 3/4" clearance to the inner wheel house & the outer lip...
Oh yeah BTW it's sitting way high, we just bolted the wheels on to test fit, the car actually runs stock 14x5.5's & redlines...
[Re: tims69belvedere]
#1833173
05/24/15 12:00 PM
05/24/15 12:00 PM
Superfreak
Superfreak
The member you asking is no longer with us. RIP Randy
