Here are some more pics. This is the port where the A/C equipped cars have that thermostatic air bleed that was on this carb, but the port wasn't drilled.
Here's the bottom:
I started with this:
I removed the plugs with these tools, turning by hand, and this is what came out:
I wish someone told me that the threads go all the way to the front of the carb. I thought the idle screws were smaller than the normal ones, and people tapped the holes for the bigger adjusters. Well, I didn't damage the threads, so all is good. I'll use the adjusters from the Edelbrock if they fit instead of the small ones.
As for that off idle adjuster--if I have problems, I'll just plug the hole.
