small block stroker oil pump to crank counter weight? #577752
01/09/10 06:27 PM
01/09/10 06:27 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
is.052 clearance between the oil pump housing and the crank counterweight acceptable? or should i gring a litle off the oil pump? motor is 9.6:1,340 4" stroke,stock volume oil pump blended inside.thanks mike
Re: small block stroker oil pump to crank counter weight? [Re: hp340nos] #577753
01/09/10 06:35 PM
01/09/10 06:35 PM
Vacherie, Louisiana
SuperStocker Offline
super gas
super gas
Vacherie, Louisiana
Plenty; go ahead and run it.
Re: small block stroker oil pump to crank counter weight? [Re: hp340nos] #577754
01/09/10 08:28 PM
01/09/10 08:28 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Like S/S says...your fine. .060 is the " accepted " norm. It cant move that much back there. Check your PMs, just sent you a note on timing.
Todd
RIP Monte Smith
Re: small block stroker oil pump to crank counter weight? [Re: CompWedgeEngines] #577755
01/09/10 11:30 PM
01/09/10 11:30 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
ok thanks guys
