I found more! More old truck questions.
#57699
05/02/08 12:29 PM
05/02/08 12:29 PM
Posts: 1,963 ID/MT
Cheeto
ID/MT
I've put the word out that I need some parts for my '37 Plymouth and I've stumbled across a couple more ol' Dodges. I was up to my eyeballs in 20's thru 50's cars and parts yesterday morning... PURE HEAVEN!!! One is about a '39 and another I couldn't see well enough in the time I had to be certain. 1) How can I tell the year from the body tags? 2) Is there a universal trick that works on all brands? There's a bunch of Internationals and a random Ford or Chevy (not to mention hoods/grilles/fenders scattered all over the place). 3) Do the 1.5(?) tons use the same cab/hood/grille as 1/2 tons? Fenders look bigger. Now I need to sell the 'Cuda and my purple truck to add on to the shop to make room for more stuff I'll never get to.
Cheeto It's not perfect. It's not correct. It's not yours!
Re: I found more! More old truck questions.
[Re: dogdays]
#57704
05/05/08 12:59 PM
05/05/08 12:59 PM
Posts: 1,963 ID/MT
Cheeto
ID/MT
I appreciate all the input guys. I was thinking the cabs were the same but not certain on hoods and grilles. I was 99% sure fenders were different. As I said, the truck in question is 2 hours away so I can not easily get measurements and it is in a field purchased by people who aren't nearby either. I have a '68 D500 out back and can see the cab/hood/grille are same as 1/2 tons of same vintage. The fenders are larger and there is a filler panel below the grille and between running boards and cab due to larger frame. On the "truck-in-the-field", I can see from pics that the filler is there for the running boards but the weeds are too tall in front of the grille shell so I can't see if it is on top of the frame (like 1/2 tons) or if it is longer to cover the front of the frame. Again, I am thankful for all the help.
[Re: earlymopar]
#57708
05/14/08 02:46 AM
05/14/08 02:46 AM
Posts: 1,963 ID/MT
Cheeto
ID/MT
Are those both the same year of truck? Headlight mounting is different between the two.
[Re: Cheeto]
#57711
05/14/08 10:40 AM
05/14/08 10:40 AM
Posts: 7,992 Escondido, CA. Ron Podsiadly,...
Mopar Ron
Model ME-32 according to tag on firewall (might be NE-32). Would first digit of serial number be model year?
I have pic of S/N tag but VIN's on the web are a
I dont know tag #s but that looks like a 36 maybe a 37 1-1 1/2 ton truck they use larger grills and fenders than the 1/2 ton models Ron..
[Re: Mopar Ron]
#57712
05/14/08 12:41 PM
05/14/08 12:41 PM
Posts: 1,963 ID/MT
Cheeto
ID/MT
I'm guessing '37/'38. All the '36s I find on the 'net have square gauges and the one '39 I've seen had the next body-style nose. Either way, I bought it. They had a '34(?) Ford and a '30s International too that were headed for the scrapper...can't save 'em all otherwise it would be me with the girlfriend and neighbors!
