mini starter #57550
04/30/08 09:50 AM
04/30/08 09:50 AM
Ohio
I
iron6 Offline OP
iron6  Offline OP
I
Ohio
I'm replacing my starter with denso mini starter.There isn't a wiring harness to connect the starter to ground or positive in the box. where can I get the wire connectors? I check Mancini and Summit didn't see them listed. Thanks
Re: mini starter [Re: iron6] #57551
04/30/08 12:19 PM
04/30/08 12:19 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Use your own wires that are already there.
Re: mini starter [Re: iron6] #57552
04/30/08 12:26 PM
04/30/08 12:26 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
The starter grounds thru the block.Rocky
Chrysler Firepower
Re: mini starter [Re: therocks] #57553
04/30/08 12:49 PM
04/30/08 12:49 PM
Upper Midwest
Upper Midwest
You only need the 2 wires already there. The starter grounds through the case to the block when bolted up.
Re: mini starter [Re: MoparforLife] #57554
04/30/08 01:53 PM
04/30/08 01:53 PM
NH
72challorange Offline
He's Game
He's Game
NH
Maybe he is looking for the adapter wire for the mini starter? JY or dealer maybe?
Tom
By tdavist, shot with DSC-P72 at 2008-04-26
Re: mini starter [Re: 72challorange] #57555
04/30/08 02:31 PM
04/30/08 02:31 PM
Upper Midwest
Upper Midwest
Just run the wires that are there. The big wire goes to the larger of the studs and small to the smaller, just like the OEM starter. Don't understand why you can't make it work.
Re: mini starter [Re: MoparforLife] #57556
04/30/08 04:39 PM
04/30/08 04:39 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
don the newer mini has a different connector for the solenoid wire
Re: mini starter [Re: JohnRR] #57557
04/30/08 06:05 PM
04/30/08 06:05 PM
NH
He's Game
He's Game
NH
I agree, that is why I posted that pic.
Tom
Has a small pin connector inside the plastic. No way to get a wire on there.
Re: mini starter [Re: 72challorange] #57558
04/30/08 06:12 PM
04/30/08 06:12 PM
Upper Midwest
Upper Midwest
Put a spice in the small wire. function will be the same. Alot of things have to be made to work.
Re: mini starter [Re: MoparforLife] #57559
04/30/08 06:48 PM
04/30/08 06:48 PM
NH
He's Game
He's Game
NH
The small wire is what he is looking for I'm guessing since he never came back. It has a funny connector on the end of it.
Tom
Re: mini starter [Re: 72challorange] #57560
06/04/08 01:28 PM
06/04/08 01:28 PM
MN
mkvien Offline
mkvien  Offline
MN
So where does a guy get the pigtail that attaches to the new style connector, short of hacking one off of a stock wire harness (which I don't have and would imagine would cost me the price of the whole harness at a yard)?
Re: mini starter [Re: mkvien] #57561
06/04/08 01:55 PM
06/04/08 01:55 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Put a new connector of your choice on the starter wire. Not rocket science just a quick wiring fix.
Re: mini starter [Re: MoparforLife] #57562
06/05/08 04:23 PM
06/05/08 04:23 PM
MN
mkvien Offline
mkvien  Offline
MN
The connector on the starter looks like this...
I purchased the starter to put on an older engine and do not have the mating connector for it. Short of putting some sort of female spade connector on it and just stuffing it into the hole, I was just wondering if there was a source for the matching connector that would have been on the factory harness. I do not see a number molded into the connector. Looking for the short chunk of wire in the guy's picture of the 2 starters above.
