External oiling Q #563620
12/26/09 11:49 PM
12/26/09 11:49 PM
Mooresburg, Tn
'72CudaRacer Offline OP
Mooresburg, Tn
When going to an external oiling system, do I need to plug the oil pick up tube port in the crank case? Any thing else that I should be on the look out for with this system? I have a dual line swinging pick up, but I'm only planing to use a single line to the pump cover. Can I just plug off the other outlet from pick up?
Thanks, Brian
Re: External oiling Q [Re: '72CudaRacer] #563621
12/26/09 11:54 PM
12/26/09 11:54 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
you can plug the hole in the block where the oilpick up would be
I have a milidon duel setup, took off the plate and made it a single oilline setup
and used the stock length oil pump drive
1.39 9.85 - 137 mph
Re: External oiling Q [Re: '72CudaRacer] #563622
12/27/09 01:13 AM
12/27/09 01:13 AM
I did use a 1/2 pipe plug to close the pickup off on the inside of the block, it does need to be plugged(if it is a non race 426 or Hemi block)on every B-RB or Hemi block if you don't use the stock pick up with the Milidon external systems
Re: External oiling Q [Re: Cab_Burge] #563623
12/27/09 07:30 AM
12/27/09 07:30 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
this is how it is in my world block... you didnt say what type of block it was etc...
Mopar Performance
Re: External oiling Q [Re: moparniac] #563624
12/27/09 05:22 PM
12/27/09 05:22 PM
Mooresburg, Tn
Mooresburg, Tn
It's a stock 440 block. Ok to just put a pipe plug in the bottom where pick up tube would be?
Thanks, Brian
Re: External oiling Q [Re: '72CudaRacer] #563625
12/27/09 05:23 PM
12/27/09 05:23 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
Thanks, Brian
yes
1.39 9.85 - 137 mph
Re: External oiling Q [Re: Ari440] #563626
12/27/09 05:35 PM
12/27/09 05:35 PM
Mooresburg, Tn
Mooresburg, Tn
Thanks. Huntin' a plug!
Brian
Re: External oiling Q [Re: '72CudaRacer] #563627
12/27/09 06:01 PM
12/27/09 06:01 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
Brian
put some red lock tigth on the threads too
1.39 9.85 - 137 mph
Re: External oiling Q [Re: Ari440] #563628
12/27/09 06:06 PM
12/27/09 06:06 PM
Mooresburg, Tn
Mooresburg, Tn
Good Idea. Thanks
Re: External oiling Q [Re: '72CudaRacer] #563629
12/27/09 06:59 PM
12/27/09 06:59 PM
You can also use a small welsh plug(freeze plug) in the block as already mentioned, it will go in the hole from the pickup under the pump, that works also, but I trust the pipe plug with thread locker more
Re: External oiling Q [Re: Cab_Burge] #563630
12/27/09 07:29 PM
12/27/09 07:29 PM
Indiana
65dragnet Offline
65dragnet  Offline
Indiana
I used a pipe plug where the pickup went and a core plug under the pump ! No wonder my junk is so heavy LOL
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
