Page 1 of 3 1 2 3
Anyone see a problem with my rollbars ??? #558676
12/20/09 05:40 PM
12/20/09 05:40 PM
Sherman Texas
The Shocker Offline OP
Sherman Texas
A friend and i installed an S and W 8 point kit for a 65-66 Dart in my 64 a few weeks ago .We did kind of a rush job (do to having a 1 day window to use the shop),but i think we got it measured out right.Its 3 inches from the back edge of my helment to the leading edge of the main hoop.Its got the seat bar below my shoulders by about 2 inches and it lower than the door bars by about 1 1/2 inches ,and the door bars cross by me between my elbow and shoulder.Anyone see a tech guy having a beef with any part of it ? If so i have a few months to fix whatevers wrong.The only rust in the floor of my car was right where the door bars attached to the front floor pan.I cut it out about 8 x 10 around it and replaced the pinholed metal with new sheetmetal butt welded in place ,then welded the door bar plates to it.Will this be a problem ?I have never done a roll bar before ,much less in a Unibody car ,and i didnt have a rule book handy ,but i did manage to get some of the specs off the net prior to the install.This is only a low 11 second car...
http://www.youtube.com/watch?v=ykcsXMV3vfg My Dart ,and im just getting started...
Re: Anyone see a problem with my rollbars ??? [Re: The Shocker] #558677
12/20/09 05:41 PM
12/20/09 05:41 PM
Sherman Texas
Sherman Texas
More pics...
Re: Anyone see a problem with my rollbars ??? [Re: The Shocker] #558678
12/20/09 05:42 PM
12/20/09 05:42 PM
Sherman Texas
Sherman Texas
More...
Re: Anyone see a problem with my rollbars ??? [Re: The Shocker] #558679
12/20/09 05:44 PM
12/20/09 05:44 PM
Sherman Texas
Sherman Texas
Another...
Re: Anyone see a problem with my rollbars ??? [Re: The Shocker] #558680
12/20/09 05:45 PM
12/20/09 05:45 PM
Sherman Texas
Sherman Texas
Last one ...
Re: Anyone see a problem with my rollbars ??? [Re: The Shocker] #558681
12/20/09 07:00 PM
12/20/09 07:00 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
The bars coming off the main hoop that are welded to the plate next to the tunnel. I have a concern depending on what type of suspension you go with. These bars should attach above your framerail. The idea is that in a roll over you can shove the main hoop through the plated floor pan. But, when you add the seventh and eighth points and attach to the fram connector, rear frame, leaf spring relocation mount, or ladder bar crossmember you rule this possibility out.
I'm not suggesting you have to remove and relocate the bars. But, maybe you could put a crossmember between frame connectors and loop it under the driveshaft to give these bars something substantial to support the main hoop.
What you have may be perfectly legal. I'm not looking at the rule book right now but the old rules said those extra bars had to connect to a frame member.
Leon
Re: Anyone see a problem with my rollbars ??? [Re: Leon441] #558682
12/20/09 07:16 PM
12/20/09 07:16 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
Leon
And to fix that he could run another piece of 1 5/8 between the main and the down bars ...then he could tie that bar into the subframe connectors...its kinda a patch way of doing it...but hes WAY too deep into it now....
Re: Anyone see a problem with my rollbars ??? [Re: The Shocker] #558683
12/20/09 07:26 PM
12/20/09 07:26 PM
Lehigh Acres, Florida
rickstershemi Offline
Well at 11.0 which was your target and not needing a cert, my says you will never have a problem and actually a pretty nice install....congrats
Rickster
Re: Anyone see a problem with my rollbars ??? [Re: rickstershemi] #558684
12/20/09 07:53 PM
12/20/09 07:53 PM
Sherman Texas
Sherman Texas
Thanks guys , i feel lots better about it now.I didnt want to get to the track and only to find out it wasnt right .I think im actually good to 10.00 from what i have been told.I think if you have an unmodified floor and firewall an 8 point bar is okay till you get to 9.99...
Re: Anyone see a problem with my rollbars ??? [Re: The Shocker] #558685
12/20/09 08:02 PM
12/20/09 08:02 PM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
Well it might be legal, but would you want to rely on it a 140+ mph? Just my
Re: Anyone see a problem with my rollbars ??? [Re: The Shocker] #558686
12/20/09 08:04 PM
12/20/09 08:04 PM
Alberta Canada
StrokerAspen Offline
Alberta Canada
Yeah it will pass tech no problem. Mine is similar, and the tech guys didn't even ask me to pull up the carpet.
Re: Anyone see a problem with my rollbars ??? [Re: moparguy7074] #558687
12/20/09 08:25 PM
12/20/09 08:25 PM
Sherman Texas
Sherman Texas
Dont ever see me going 140+ on my wallet in this car ,but its nice to know that if i break 11.00 im still good for another second ...
Re: Anyone see a problem with my rollbars ??? [Re: StrokerAspen] #558688
12/20/09 08:30 PM
12/20/09 08:30 PM
Sherman Texas
Sherman Texas
Thanks for the pics StrokerAspen ,it does look very simular to my install .I dont plan on putting carpet in mine anyway ,since its a drag only car ,but its nice to know they didnt question how yours was attached to the floors.I guess tech depends on the man doing it at that track ,but i think im good for the most part from what you and everyone else is saying.Thanks again for posting the pics of your car ...
Re: Anyone see a problem with my rollbars ??? [Re: The Shocker] #558689
12/20/09 08:32 PM
12/20/09 08:32 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
My car done the same way been that way for years..
Re: Anyone see a problem with my rollbars ??? [Re: The Shocker] #558690
12/20/09 08:58 PM
12/20/09 08:58 PM
TMP66 Offline
TMP66  Offline
Looking at those welds on the right side support bar it looks like the welder did the on/off on/off of the trigger overlapping spot welds instead of a vertical up weld. Almost no HAZ indication next to the weld.
I hope he didn't use this method on the rear supports at the hoop.
Re: Anyone see a problem with my rollbars ??? [Re: TMP66] #558691
12/20/09 09:31 PM
12/20/09 09:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its called stitch welding.... works fine
Re: Anyone see a problem with my rollbars ??? [Re: TMP66] #558692
12/20/09 09:33 PM
12/20/09 09:33 PM
okla.
sam64 Offline
sam64  Offline
okla.
it looks good daniel,paint it and be done.iv'e been freshening the top end on my 65 coronet,putting a smaller tube header on it hoping to making a little more low end power.have a good holidays,sam.
Re: Anyone see a problem with my rollbars ??? [Re: The Shocker] #558693
12/20/09 09:37 PM
12/20/09 09:37 PM
ill
dennismopar73 Offline
ill
great welds
the only problem i see
what size is it looks like 1"5/8
that is not leagal bar
roll bar must be 1"3/4
gage can all be
1"5/8
Re: Anyone see a problem with my rollbars ??? [Re: sam64] #558694
12/20/09 09:49 PM
12/20/09 09:49 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
I think that roll bar looks great for the time you had and it looks safe enough to me and I think it will pass tech for sure.
But I am going to say something just so others will have the info.
Rule book says the main hoop has to be attached to the "rocker sill". MOST tech's won't ding you on this. But, you want to keep the main hoop from pushing those 6X6 plates through the floorpan.
If you really wanted to make it safer you can add the 2 bars that would go to the top of your frame ties like was mentioned. I personally think it looks fine and will pass tech.
SRT DEMON ONE SEAT
Re: Anyone see a problem with my rollbars ??? [Re: MR_P_BODY] #558695
12/20/09 09:58 PM
12/20/09 09:58 PM
TMP66 Offline
TMP66  Offline
Yes, it is called "stitch welding" and in this application it does not "work fine". It should have a proper 'stringer' weld. Stitch weld your new quarter panels, not a roll bar.
Here's some more on the subject....
http://www.millerwelds.com/resources/communities/mboard/archive/index.php/t-5923.html
Maybe some certified welders will jump in here also.
Page 1 of 3 1 2 3
