Wheels 1969 roadrunner vs 1964 fury #558525
12/20/09 02:20 PM
12/20/09 02:20 PM
Netherlands
cultphotos Offline OP
Netherlands
Hi can anybody tell me if wheels from my 1969 roadrunner would fit an 1964 plymouth fury?
Kind regards,
Marcel
Re: Wheels 1969 roadrunner vs 1964 fury [Re: cultphotos] #558526
12/20/09 02:31 PM
12/20/09 02:31 PM
Doo-Dah, KS
440fied Offline
440fied  Offline
Doo-Dah, KS
They should bolt right on. Both cars share the same dimensions, 5 lugs on a 4.5 inch diameter circle also known as 5 on 4.5"
There are other considerations though, like wheel back spacing, tire width and height, etc...
Re: Wheels 1969 roadrunner vs 1964 fury [Re: cultphotos] #558527
12/20/09 02:33 PM
12/20/09 02:33 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The bolt pattern is the same, but the Roadrunner has a bigger wheelwell so if the wheels are on the large side they may not fit but if they are stock type wheels then they should fit...
Re: Wheels 1969 roadrunner vs 1964 fury [Re: cultphotos] #558528
12/20/09 02:48 PM
12/20/09 02:48 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Kind regards,
Marcel
If they're stock steel wheels you're good. They don't have the same center hub diameter so dog dish caps won't interchange.
Re: Wheels 1969 roadrunner vs 1964 fury [Re: cultphotos] #558529
12/21/09 12:15 AM
12/21/09 12:15 AM
PA
U
unclemike Offline
unclemike  Offline
U
PA
I had the same questions back in the day when the 15x7" rally wheels first came out. All the "experts" said they wouldn't fit my 1964 Plymouth Savoy.
So I bought two wheels jacked the car up and undid the torsion bar adjusters and bolted the wheels on.
Guess what? They cleared everything from full jounce to full rebound.
I've since run 15x8" with no problems as far as the wheel clearing suspension parts goes on 1968 Sport Satellites.
Tires are another matter.
My 1964 Plymouth Sport Fury (not to be confused with 1965) has 15x6.5" wheels with 215/70 Radial T/As no clearance problems at all. On the back I have 255/60's on 15x8" wheels with no problems. I tried 275's on the same wheel but they hit the lip. I replaced the axle with one out of a 1966 Dodge coronet wagon so it's wider. My next experiment will be 245/60's on 15x8" wheels on the front.
Re: Wheels 1969 roadrunner vs 1964 fury [Re: unclemike] #558530
12/21/09 01:16 AM
12/21/09 01:16 AM
Hubcap diameter on the '64 wheel is much larger than later ones but other than that they'll bolt up.
*Edit*
Doh, I see someone already mentioned that!
