Re: where is my oil going?
[Re: 64Post]
#558030
01/04/10 01:51 PM
01/04/10 01:51 PM
Posts: 4,177 California
mickm
California
... You can put the gage on the dipstick tube, but I have the feeling you'll see for yourself the breather(s) being pushed up off the valve covers. AFAIC this is a straight forward blow by issue -- you've eliminated everything else. How much you can tolerate is up to you. Using two breathers might mask the issue, but it certainly won't fix it.
I really don't see how you can avoid re-honing and re-ringing the engine. Trust me, I'm in the same boat except as you, but right now I don't have the time or money to fix it.
i was planning on going this coming friday, just to tune it in. while it doesn't perform the way i want it to, it still is no slouch. and i know the A/F could still be dialed in better.
i agree that i will have to re hone/ring it, but for now i just have to figure a way to keep the oil inside the engine. there has to be a way to do that, even if i have to rig a more extensive baffle system inside the valve cover...
[Re: mickm]
#558031
01/04/10 07:36 PM
01/04/10 07:36 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
I said before the smart way is to sddress the problem. Yes, it stinks but everything points to a ring sealing issue. It's not designed to hold pressure in. It's designed to NOT HAVE PRESSURE in the crankcase. The more you have, the more issues will be with ring seal (AKA vacuum pumps for race engines that encourage ring seal...) I dont think you'll be able to seal it up. Plug all the obvious points and it will start pushing out the rear main and gaskets. I wish you luck, but I think it's a fruitless endeavor.
[Re: mickm]
#558032
01/04/10 07:52 PM
01/04/10 07:52 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
Mick my friend, I sure do feel your pain.
