Re: Tips and tricks or How I learned not to do something.
[Re: T-Man]
#557382
12/20/09 11:31 PM
12/20/09 11:31 PM
Posts: 228 northeast texas
strokin73cuda
northeast texas
Use a vacuum hose on the end of spark plugs to screw them in or out. If you run out of masking tape put grease on the small parts you don't want painted then just wipe off with a rag when done. If you can't get your oil pump to prime up try filling the crankcase with extra oil even above the elevation of the pump then drain the extra oil when done. NEVER hook booster cables or chargers ground cable directly to the battery ground. hook up the positive side first then the ground side to a suitable location away from the battery to prevent sparking and potential explosion (dont' ask how I know )
496 stroker,Indy srs , new best 6.87 @ 98 1.46 60'
[Re: T-Man]
#557383
12/21/09 11:56 AM
12/21/09 11:56 AM
Posts: 3,968 North Riverside IL & Lowell IN
GTXKen
super gas
super gas
On extremely hard to get at busted off studs, bolts, etc. get an explosives expert to POP it out.
Good tip, I've been wondering what to do with that explosives expert I had stashed
[Re: GTXKen]
#557385
12/21/09 03:58 PM
12/21/09 03:58 PM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
The best way to drain fluids out of things that have no drain plugs (auto trannies, 8 3/4 rears) is with a drill. Drill fast to minimize the mess but when done, install a plug.
The auto tranny retrofit plug kits work good and an 1/8" NPT plug in the rear housing works good too.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
[Re: CJK440]
#557388
12/21/09 04:07 PM
12/21/09 04:07 PM
Posts: 21,819 Kirkland, Washington
Pacnorthcuda
If you have to work on the floor under the car and don't like creepers (like I don't) you probably already lie on a piece of old carpet. In the winter for addes insolation I like on a couple pieces of the pink house wrap insolation, it makes a huge difference.
Or go buy a rubber work out/gym mat.
Or use a piece of cardboard, when it gets dirty throw it out.
[Re: Crizila]
#557390
12/21/09 05:21 PM
12/21/09 05:21 PM
Posts: 8,861 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I hope you mean the rigid stuff and not fiberglas ... that stuff's a b!tch to get out of your clothing!
[Re: Stanton]
#557391
12/21/09 06:27 PM
12/21/09 06:27 PM
Posts: 7,506 Az
Crizila
Az
Running eliminations on a 95 degree day and there is 140 cars in your class? I fill up a plastic spray bottle with cold water from my cooler and toss it in the car. While I'm in the staging lanes, I will pop the hood and mist down the radiator. By the time I get ready to make a pass, I be Cool!
Fastest 300
[Re: Crizila]
#557392
12/21/09 07:29 PM
12/21/09 07:29 PM
Posts: 3,426 weymouth,mass.
meepmeep70
weymouth,mass.
1)if you drop a bolt,nut screw,tool ect.,just let it fall and watch it,don't try to catch it,cuz you won't,you will fumble it bounce it off your car or knock it to that place where things go to never be found,and it still fell,just let it go and you will see where it is,dropped a wrench,tried to grab it and it bounced of my hand into my car,luckly before paint 2)if you need to put several extensions together,like reaching through trunk,tape them together so they wont pull apart 3)grease in a socket will hold a nut in place when going on a tight vertical spot 4)wrapping cardboard on your bumper ends when installing or removing will save your paint. this could be a great thread
[Re: meepmeep70]
#557393
12/21/09 07:41 PM
12/21/09 07:41 PM
meepmeep70
weymouth,mass.
when installing new headliner,install all screws with rough location measurements for seat belts,coat hooks,visors,dome light,mirrior,ect,install headliner,it is easier to feel the screw head the a screw hole,make a small slit on screw head and back out screw install whatever that screw holds perfectly and watch as your headliner wrinkles go away
[Re: RapidRobert]
#557395
12/21/09 08:29 PM
12/21/09 08:29 PM
Posts: 2,590 Piqua, Ohio
dodgeram440
Piqua, Ohio
if you can't get your oil pump to prime up try filling the crankcase with extra oil even above the elevation of the pump then drain the extra oil when done.
there's been a couple of posts here in the last several months where guys were pulling their hair out as absolutely could not get their eng to prime. Your unthinkable tip would have done it
I heard you can take the cover off and pack the rotors full of vaseline. That will get it to prime right away. I've never tried it, but it's what I've heard.
[Re: dodgeram440]
#557399
12/21/09 10:06 PM
12/21/09 10:06 PM
Challenger 1
Cincinnati, Ohio
I've done it with every build I've ever done, use just reg chassis grease. Thought it was a automatic thing to do to a new oil pump?
