what's the difference between... #555886
12/17/09 01:23 AM
12/17/09 01:23 AM
TN
'84 D150 Shorty Offline OP
Pickup Man
Pickup Man
TN
been looking at different bellhousing casting numbers tying to determine which would be best for me... some are listed as for E Body, and some as truck, etc. What's the difference? Does the clutch pedal mechanism bolt up the same?
Re: what's the difference between... [Re: '84 D150 Shorty] #555887
12/17/09 07:49 AM
12/17/09 07:49 AM
There is probably a difference between the z bar mounts but also the truck clutch is an 11" and the car clutch is 10 1/2" which may or may not make a difference. I assume your talking small block?
What part numbers are you looking at?
