Carb gasket question?? #552691
12/13/09 02:29 PM
12/13/09 02:29 PM
Eugene, Oregon
minivan Offline OP
minivan  Offline OP
Eugene, Oregon
I have a stock carter on my stock 4 barrel intake manifold... The parts store sold me a carb to manifold gasket that only has the gasket material around the perimeter of the carb, not inbetween the throttle bores.. Will this work OK on my car??
Re: Carb gasket question?? [Re: minivan] #552692
12/13/09 03:21 PM
12/13/09 03:21 PM
Az
Crizila Offline
Crizila  Offline
Az
If it's under 1/4" thick you won't notice the difference - as long as you have no outside vacuum leaks.
Fastest 300
