Re: E body Fuel Tank Vent Location
[Re: cataclysm80]
#54803
03/14/08 08:19 AM
03/14/08 08:19 AM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
I just pulled mine out the other night. I'll get you some pics of oval cut out with the location measurements later this morning. Should be able to get you fixed up. Joe
65 Barracuda 70 Challenger
[Re: cataclysm80]
#54805
03/14/08 09:59 AM
03/14/08 09:59 AM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
Hopefully these 2 photos will help. If you need something else then let me know.
[Re: jrwoodjoe]
#54807
03/14/08 10:03 AM
03/14/08 10:03 AM
Posts: 4,165 Florida
cataclysm80
PERFECT!! Thank you very much! Tav (did you get your fender converted over to 70 style yet?)
[Re: cataclysm80]
#54808
03/14/08 10:08 AM
03/14/08 10:08 AM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
Not yet. I'm still a little about it and that I didn't notice until a few days ago. I do not have a welder so the guy who is doing my media blasting has been doing my sheet metal repair also. I'll have him do it when I take the rest of the car over to be blasted. Thanks, Joe
[Re: 71 Six Pack]
#54812
03/14/08 12:48 PM
03/14/08 12:48 PM
Posts: 3,896 St. Louis, MO
Blues_Cuda
St. Louis, MO
The one on my '70 Challenger is a grommet with a large tube, similar to fuel fill.
Possibly an emissions deal...ECS?
We have a '70 Barracuda that originally had the large vent tube in the trunk that was about the same diameter as a fuel fill. It had 4 smaller lines at the very bottom that ran to the gas tank and/or fuel return.
I replaced the whole nine yards with the standard fuel tank and vent assembly.
[Re: 71 Six Pack]
#54814
03/15/08 10:25 PM
03/15/08 10:25 PM
Posts: 1,573 Rockford, IL.
Ruppman
Rockford, IL.
Maybe, car is a California car with the California emissions called out on the Fender Tag. I recall only one vent tube coming out of the tank though. My 71 has 4 vent tubes coming out of the tank.
Joe
Right, California sold vehicles only in 70. Should have N95 on the fender tag. ECS is Evap control. routes the carb bowl gas fumes back to the tank instead of letting them vent to atmosphere.
Mark
[Re: Ruppman]
#54817
03/16/08 11:50 AM
03/16/08 11:50 AM
Posts: 100 Rhode Island
71 Six Pack
Rhode Island
Mark
The fender tag does have N95, California Emissions called out. I'm pretty sure the tank only had one tube coming out of it. I'll have to double check, which will be easy as the original tank is out of the car due to a leak.
So California emissions is basically carb fumes back to tank correct? That would mean I should have two lines from the fuel tank to the carb, one for supply, one for vent return. The emissions do not also include the 3-tube breather as well do they?
Thanks,
Joe
