Duster Mini tub question #546182
12/05/09 04:09 PM
12/05/09 04:09 PM
On the parachute mount
N
n20mstr Offline OP
n20mstr  Offline OP
N
Ok im about to mini tub my sons duster, i am doing the usual split the tub and moving it up to the fram rail, NOW when i look at the outer part it has a lot of room to the qtr panel, maybe like 2" is it worth it or has anyone sectioned that outer part ?? Seems like the tire will never get up that far anyway, well at least not with a leaf spring suspension...We are only looking to run a 295 radial but would be nice to fit a 315 in there also...thanks
....BAD A$$ STREET CAR.....
Re: Duster Mini tub question [Re: n20mstr] #546183
12/05/09 04:21 PM
12/05/09 04:21 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
I know the exact spot you are talking about... I have attached a few pics of my car with a set of 28x13.50 et streets on 12" wheels. im mini tubbed, and springs relocated. I can tell you with confidence that a 295 or 315 is just to tall with out streching the wells. I just ordered a set of 315/60 et street radials, and thats the avenue I have to take to get them to fit.
Re: Duster Mini tub question [Re: joshking440] #546184
12/05/09 04:21 PM
12/05/09 04:21 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
#2
Re: Duster Mini tub question [Re: joshking440] #546185
12/05/09 04:23 PM
12/05/09 04:23 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
#3
Re: Duster Mini tub question [Re: joshking440] #546186
12/05/09 04:24 PM
12/05/09 04:24 PM
N
n20mstr Offline OP
n20mstr  Offline OP
N
the car is almost ready for paint and im going to trim the front up to the rocker, and the rear also, im not going to stretch the opening, just trim the front and rear...I have 295s on my dart and the front is trimmed up to the rocker...SO is you car just mini tubbed on the inner part?? Thanks
Re: Duster Mini tub question [Re: n20mstr] #546187
12/05/09 04:29 PM
12/05/09 04:29 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Yea, i just took the stock wheel tub in. I took the notch where the truck mounts are out and formed a piece of metal to keep it from intruding with the tire...if that makes sense
Re: Duster Mini tub question [Re: joshking440] #546188
12/05/09 04:38 PM
12/05/09 04:38 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
joshking440
you have any more pics of your car please
1.39 9.85 - 137 mph
Re: Duster Mini tub question [Re: joshking440] #546189
12/05/09 04:39 PM
12/05/09 04:39 PM
need some inside trunk pictures josh?
Re: Duster Mini tub question #546190
12/05/09 04:51 PM
12/05/09 04:51 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
My car is a 69 Valiant, I have a set of 275/60/15, I could get something wider but need to get 1" more back spacing , only minitub
Re: Duster Mini tub question #546191
12/05/09 06:00 PM
12/05/09 06:00 PM
Way out in the sticks of Weste...
DusterDog Offline
DusterDog  Offline
What did you do with the flange at the top of the rear frame rail?? Cut it off, or bend it up??
"I've upped my horsepower, so...... UP YOURS!!!"
Re: Duster Mini tub question [Re: n20mstr] #546192
12/05/09 06:01 PM
12/05/09 06:01 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I never touched the outer 1/2 of the wheel well. 28 x 11.5" ET Drag fits without a problem.
Re: Duster Mini tub question [Re: dizuster] #546193
12/05/09 06:01 PM
12/05/09 06:01 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Another
Re: Duster Mini tub question [Re: dizuster] #546194
12/05/09 06:03 PM
12/05/09 06:03 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Last. By the way, I have a .ppt with about 50 step by step photo's pictures how to mini-tub a duster. Anyone can send me a PM with your email address and I'd be glad to send it to you.
Re: Duster Mini tub question [Re: dizuster] #546195
12/05/09 06:39 PM
12/05/09 06:39 PM
DusterDog Offline
DusterDog  Offline
Scott,
Your PM box is full!!!!!!
Re: Duster Mini tub question [Re: DusterDog] #546196
12/05/09 08:27 PM
12/05/09 08:27 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Whoops! Sorry about that. Should be good now!
Re: Duster Mini tub question [Re: n20mstr] #546197
12/06/09 06:10 PM
12/06/09 06:10 PM
I stretch my 1971 Duster wheel wells five inches so these tires(315x60x15) would look stock I had the front edge moved forward three ichess and the rear moved back two inches, the rear end center was moved forward one inch also while installing the ladder bar and coil over rear suspension BTW, 10.5x31x15W fit well also
