Re: ALUMINUM MASTER CYLINDER QUESTION???
[Re: GoodysGotaCuda]
#54387
02/28/08 11:21 AM
02/28/08 11:21 AM
Posts: 2,560 S.E. Michigan
cl440
S.E. Michigan
Now, why the caps seep brake fluid...thats another story.
Mine does the same thing!
[Re: moparrush]
#54389
02/28/08 01:17 PM
02/28/08 01:17 PM
Posts: 134 san antonio, Texas
moparrush
san antonio, Texas
On the car, I had purchased one from the local parts house, and it was a steel piece. A, it didn't work worth a damn, and B, it rusted all to hell in a matter of months. Spilled dot 3 on those eats the paint and they rust quick, but that's another topic. So when going to swap the MC's last night, I was trying to salvage the rubber retainer (Trying key word) and when checking the new aluminum one there was no resistance when I put the rod in. Of course this was all done on the bench, so taking a flashlight, and a scribe, I looked at the back of the piston, and it was smooth machined to the cup at the bottom, whereas, the steel one had been machined for the retainer. It is obvious when you compare the two. I think I'm going to disasseble the steel one, and see if the piston is swapable, and maybe that will solve my problem. The only other option I can see it to remove the piston and go and have it machined for the retainer, but what a pain in the butt, and cost, that would be. I guess I'm looking for the easy way out, but sometimes the easiest isn't always the cheapest, and vice versa. Oh, and yes mine is a manual brake car, and I was told that it would work with my setup. No mention of the retainer though, either by myself or the seller. I didn't think to ask at the time. Now that I am doing the swap, I learned another interenet parts buying lesson. You gotta ask the right questions before you buy from here, ebay, or anywhere on the net, because if you don't than it's going to bite you.
[Re: cl440]
#54391
02/28/08 01:28 PM
02/28/08 01:28 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Thats interesting, i've taken the little gasket out, cleaned it up. I havent driven it much since, but i put some black rtv behind the cap gasket, hoping to pushdown on the reservoir more and seal. So far nothing, but again, not too many miles
[Re: moparrush]
#54394
02/28/08 01:56 PM
02/28/08 01:56 PM
Posts: 1,647 IL
71383beep
IL
This is a good post. I just bought one from him about a month ago and never thought to check the piston for the slot. I will check mine tonight too. That's unfortunate that some out there are leaking too. That's the whole reason I am swapping!
'73 GK6 Challenger Rallye - 340 4-Speed
[Re: moparrush]
#54397
02/28/08 03:33 PM
02/28/08 03:33 PM
Posts: 515 Dayton, Ohio
65cuda
mopar addict
mopar addict
Dayton, Ohio
Yes let us know. i haven't got mine together yet to try it. i noticed it didn't have the grove but i didn't want to complane about it until i tried it.
65 Cuda 360,3.23 SG-13.97 @99.4, 88 D100, 2000 Kota Qcab, 71 Duster 416 11.84 @110., 73 Imp ,(2)72 & (1)71 Dart Swingers GarysMocars Legendary Dealer
[Re: 65cuda]
#54398
02/28/08 08:06 PM
02/28/08 08:06 PM
Posts: 1,647 IL
71383beep
IL
Correct or educate me if i am wrong, but what would happen if it did not have the retainer? The spring inside the reservoir pushes the piston back which in turn should return the pedal to the starting position. Even if the spring or piston fails then the pedal would stay put. right? Curious indeed...
[Re: 71383beep]
#54399
02/28/08 08:11 PM
02/28/08 08:11 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
The point of the retainer is, say you go to hit the brakes. Take your foot off the gas, heads over to the brake pedal, coming up you catch the brake pedal. lifting it up some, pushrod can fall out = no brakes. I've caught it before with my foot, i have a retainer so no issue.
But its not to return the m/c, its a pushrod retainer.
[Re: 71383beep]
#54400
02/28/08 08:14 PM
02/28/08 08:14 PM
Posts: 824 NH
72challorange
He's Game
He's Game
NH
The pushrod could pull out if you pull back on the brake pedal. Goody beat me to it.LOL
My instructions said to use a little Super Glue to hold the retainer in. If that don't work then use silicone to hold it in.
Tom
#54401
02/28/08 08:16 PM
02/28/08 08:16 PM
65cuda
mopar addict
mopar addict
Dayton, Ohio
Right the only thing holding the rod in the M/C is the retainer. well the brake light sw is behind the petal but it would bend out of the way easy.
