68-70 b-body outer wheelhouses #53964
02/24/08 12:42 PM
02/24/08 12:42 PM
eastern,Ky
70RT Charger Offline OP
eastern,Ky
I bought a set of rust free complete inner and outer wheelhouses off of a 68 4-door coronet after being told they would work on my charger.After looking at them the inners look the same but the outers looks like the lip might be about a inch lower than my chargers,I cant hardly tell because mine are rusted out.Can anybody please confirm if they are or are not the same.Thanks
Re: 68-70 b-body outer wheelhouses [Re: 70RT Charger] #53965
02/24/08 04:48 PM
02/24/08 04:48 PM
Mass
charge70 Offline
charge70  Offline
Mass
The inner wheel houses are the same Charger to Coronet 2 dr or 4 dr.Charger and Coronet 2 dr outers are the same,but 4 dr Coronet outers are different.I checked the part#'s in the book and this is what I came up with. John.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: 68-70 b-body outer wheelhouses [Re: charge70] #53966
02/24/08 07:50 PM
02/24/08 07:50 PM
eastern,Ky
eastern,Ky
Thanks John a bunch,ill just whack the outers off and order me a set.Chris
Re: 68-70 b-body outer wheelhouses [Re: 70RT Charger] #53967
02/25/08 12:53 AM
02/25/08 12:53 AM
USA
CrAlt Offline
CrAlt  Offline
USA
does anyone repo the inner and outer for 69 coronet 2dr?
I was asked to contribute money to help solve the civil unrest in Egypt, but I suspect it's some sort of pyramid scheme.
Re: 68-70 b-body outer wheelhouses [Re: CrAlt] #53968
02/25/08 02:50 AM
02/25/08 02:50 AM
Burnaby BC
N
NMike Offline
NMike  Offline
N
Burnaby BC
AMD is said to be bringing some out.
Re: 68-70 b-body outer wheelhouses [Re: CrAlt] #53969
02/25/08 05:39 PM
02/25/08 05:39 PM
Edgartown, MA/ Greene, ME
CharlieB Offline
CharlieB  Offline
Outers are available and fit tolerably. Inners need to be "worked" LOL
Re: 68-70 b-body outer wheelhouses [Re: CharlieB] #53970
02/25/08 09:11 PM
02/25/08 09:11 PM
USA
CrAlt Offline
CrAlt  Offline
USA
Hey is that my car? lol. Thats where mine where rotted. I replaced the trunk floor and full 1/4's but sitll have the crappy wheel houses. I wish I did something about them BEFORE I put the 1/4s on but that would have made to much sense i guess..
NMike, who is AMD and do they have an ETA? Im looking to have the car running around this spring and those wheel wells is the last big peace of body work i need to take car of.
Re: 68-70 b-body outer wheelhouses [Re: CrAlt] #53971
02/25/08 10:18 PM
02/25/08 10:18 PM
CharlieB Offline
CharlieB  Offline
Tell me about it!! Oh the humanity
Re: 68-70 b-body outer wheelhouses [Re: 70RT Charger] #53972
02/26/08 11:08 AM
02/26/08 11:08 AM
near Port Huron, MI
Paul Offline
Paul  Offline
near Port Huron, MI
all 68-70 b-body 4-door outer wheelhouses are the same as a Plymouth b-body two door. The inners are the same for all. Coronet 2-doors and Charger share the same outers.
Re: 68-70 b-body outer wheelhouses [Re: Paul] #53973
02/26/08 01:28 PM
02/26/08 01:28 PM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
I recently ran into major problems trying to use Goodmark's "Authentic Reproduction" Dodge B-Body outer wheelhousings on my 1969 Charger 500. I believe the same parts are sold by other vendors as well.
To read about the differences and other problems that I encountered check out my restoration thread starting at post #514...
http://www.dodgecharger.com/forum/index.php/topic,33799.510.html
I would get used wheelhousings or wait for AMD's repros...
XS
Re: 68-70 b-body outer wheelhouses [Re: xs29j8] #53974
02/26/08 07:44 PM
02/26/08 07:44 PM
CharlieB Offline
CharlieB  Offline
Not a perfect solution, but when your trying to save one of these you do what you can. Perhaps the next generation of restorers will have better material and can redo what we've left behind.
Re: 68-70 b-body outer wheelhouses [Re: xs29j8] #53975
02/26/08 08:13 PM
02/26/08 08:13 PM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
Here is a major example of the problems with the Goodmark "Authentic Restoration" outer wheelhouse...
XS
Re: 68-70 b-body outer wheelhouses [Re: xs29j8] #53976
02/26/08 08:16 PM
02/26/08 08:16 PM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
Here is another angle showing the mis-match before the black color was removed by plastic media blasting...
XS
Re: 68-70 b-body outer wheelhouses [Re: xs29j8] #53977
02/26/08 08:20 PM
02/26/08 08:20 PM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
Here is what others have done to make them work... still requires other mods to the flange to make it barely usable...
XS
Re: 68-70 b-body outer wheelhouses [Re: xs29j8] #53978
02/26/08 08:22 PM
02/26/08 08:22 PM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
Another example...
Re: 68-70 b-body outer wheelhouses [Re: xs29j8] #53979
02/26/08 08:24 PM
02/26/08 08:24 PM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
Another problem area is the forward attaching flange...
Re: 68-70 b-body outer wheelhouses [Re: xs29j8] #53980
02/26/08 08:26 PM
02/26/08 08:26 PM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
Another view...
Re: 68-70 b-body outer wheelhouses [Re: xs29j8] #53981
02/26/08 08:28 PM
02/26/08 08:28 PM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
Here is how the forward flange should look...
Re: 68-70 b-body outer wheelhouses [Re: xs29j8] #53982
02/26/08 08:35 PM
02/26/08 08:35 PM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
I believe that the repros from Auto Metal Direct will finally provide the Mopar restorer with high quality parts. I received my first AMD part last week, the new one-piece Charger trunk floor... LOOKS EXCELLENT! If it fits well (and I believe that it will!), I will be buying all my repro sheetmetal from AMD...
Here's a picture...
XS
Re: 68-70 b-body outer wheelhouses [Re: xs29j8] #53983
02/26/08 08:41 PM
02/26/08 08:41 PM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
The AMD trunk floor seems to have all the cutouts & holes... even the screw holes for attaching the filler tube seal!
Also, the metal sheet thickness seems to be correct or at least very near to the original... not half as thick like some repro sheetmetal parts are!
XS
