727 Band Material? #53840
02/13/08 09:32 PM
02/13/08 09:32 PM
W. Kentucky
justinp61 Offline OP
W. Kentucky
For a street/strip 727 with a manual valve body what band material should I use? What is a flex band?
Thanks, Justin
Re: 727 Band Material? [Re: justinp61] #53841
02/13/08 09:41 PM
02/13/08 09:41 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
pictures always help me.
Re: 727 Band Material? [Re: justinp61] #53842
02/14/08 08:26 AM
02/14/08 08:26 AM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
I prefer the Red lined rigid kickdown bands. They are less abrasive on the drum surface and withstand high line pressure manual valvebodies which tend to rip the spot welds on a flex band. A flex band has a "flexable" steel backing which conforms to the drum shape and is cheap to manufacture. The bad part is when used with high pressure valvebodies, it can fail. Some add more welds and stiffner plates around the anchor points to help eliminate this problem. For a street car with a stock VB, you can use the flex band with red or Kevlar lining. On a race application or high pressure VB with or without transbrake, use the Red lined rigid band for 2nd gear. Never use a Kevlar band on an aluminum drum. John
Re: 727 Band Material? [Re: justinp61] #53843
02/14/08 06:27 PM
02/14/08 06:27 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Pics of rigid and flex band.
Re: 727 Band Material? [Re: John_Kunkel] #53844
02/14/08 08:44 PM
02/14/08 08:44 PM
W. Kentucky
W. Kentucky
Thanks guys , I'll order the red solid band. Today I installed the extra springs in the front clutch so now all I need is a new band, 4.2 lever and hd strut.
Re: 727 Band Material? [Re: John_Kunkel] #53845
01/19/09 03:10 PM
01/19/09 03:10 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Correct me if I am wrong but the bands pictured are rigid and semi-rigid since it is preformed in a round shape.
I thought a true flex band is manufactured as a flat piece of steel that you wrap around the drum.
Or no?
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: 727 Band Material? [Re: CJK440] #53846
01/19/09 08:03 PM
01/19/09 08:03 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
Or no?
That picture has 1 flex band 1 solid standard and 1 solid hemi band
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 727 Band Material? [Re: dusturbd340W5] #53847
01/19/09 08:09 PM
01/19/09 08:09 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
I like the ATI Kevlar band on a stock iron drum, also a Kevlar blanket!
Re: 727 Band Material? [Re: DusterW2] #53848
01/19/09 09:35 PM
01/19/09 09:35 PM
NC
440Jim Offline
440Jim  Offline
NC
I agree with DusterW2.
Then again, he did teach me about 727 transmissions...
I do feel that a rigid front band and a '70-older front servo do release better during the 2-3 shift. The '71-newer oil cushioned servos have only 1 spring, but the oil cushioned part can be shimmed solid for some benefit.
