Page 3 of 4 1 2 3 4
Re: A12 “Mr. Six-Pack” Camshaft... #53607
02/03/08 01:34 AM
02/03/08 01:34 AM
Madera, CA.
MowP4rsn Offline
MowP4rsn  Offline
Madera, CA.
Thanks for this thread.
I sent Bob an email yesterday mentioning I read about him in this post, and this morning he replied, provided several phone #'s to get a hold of him to talk about using his automatic cam in my 300. Wow!
Update: 2/4/08 I called Bob today, what a great guy! Very helpful, full of all kinds of information and willing to help with cam setup, should I need it.
I think his price of $235 (cam only, but includes shipping)for one of HIS cams with Chrysler lobes instead of Chevy lobes is $$ WELL SPENT! I'll be sending a check out his way.
Re: A12 “Mr. Six-Pack” Camshaft... [Re: MowP4rsn] #53608
02/29/08 07:22 PM
02/29/08 07:22 PM
Madera, CA.
MowP4rsn Offline
MowP4rsn  Offline
Madera, CA.
Hubba-hubba!! It's HERE!!!! WOOOOOOOHOOO!!
Re: A12 “Mr. Six-Pack” Camshaft... [Re: MowP4rsn] #53609
02/29/08 07:23 PM
02/29/08 07:23 PM
Madera, CA.
MowP4rsn Offline
MowP4rsn  Offline
Madera, CA.
Just like having Christmas again
Re: A12 “Mr. Six-Pack” Camshaft... [Re: MowP4rsn] #53610
02/29/08 07:24 PM
02/29/08 07:24 PM
Madera, CA.
MowP4rsn Offline
MowP4rsn  Offline
Madera, CA.
Re: A12 “Mr. Six-Pack” Camshaft... [Re: MowP4rsn] #53611
02/29/08 07:25 PM
02/29/08 07:25 PM
Madera, CA.
MowP4rsn Offline
MowP4rsn  Offline
Madera, CA.
No CHEBBIE lobes!
Re: A12 “Mr. Six-Pack” Camshaft... [Re: MowP4rsn] #53612
02/29/08 07:26 PM
02/29/08 07:26 PM
Madera, CA.
MowP4rsn Offline
MowP4rsn  Offline
Madera, CA.
I can't wait to hear this making my 440 rumble and SING
Re: A12 “Mr. Six-Pack” Camshaft... [Re: MowP4rsn] #53613
02/29/08 07:28 PM
02/29/08 07:28 PM
Madera, CA.
MowP4rsn Offline
MowP4rsn  Offline
Madera, CA.
Tech tips for this cam, just thought I'd share
Re: A12 “Mr. Six-Pack” Camshaft... [Re: MowP4rsn] #53614
02/29/08 07:31 PM
02/29/08 07:31 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
the only thing i disagree wit hthere is shimming the rocker shaft for proper preload , thats going to affect rocker to valve tip geometry if you get too carried away
Re: A12 “Mr. Six-Pack” Camshaft... [Re: JohnRR] #53615
02/29/08 08:16 PM
02/29/08 08:16 PM
Madera, CA.
MowP4rsn Offline
MowP4rsn  Offline
Madera, CA.
John, I agree. I'd change the pushrod length first, should it come to it.
Then again, Bob worked with Tom Hoover
Bob did tell me specifically when the valvetrain is assembled, and the lifter is on the base circle of the lobe, make sure the plunger in the lifter is not touching the retainer in the lifter body, but is just under it.
Re: A12 “Mr. Six-Pack” Camshaft... [Re: MowP4rsn] #53616
02/29/08 09:33 PM
02/29/08 09:33 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
you'll need to assemble it and check , if you need no more than .010 worth of shim then go for it , but check the rocker contact sweep , if its ok , run it , otherwise do it right ...
at least thats what i would be doing .
Re: A12 “Mr. Six-Pack” Camshaft... [Re: JohnRR] #53617
03/01/08 12:07 AM
03/01/08 12:07 AM
Madera, CA.
MowP4rsn Offline
MowP4rsn  Offline
Madera, CA.
I have to agree with everything you said. When it's time to have the engine re-done and install the 440source heads, I'll find out then if anything needs any kind of shimming or whatnot.
Still, I'm pretty about gettign the cam.
Re: A12 “Mr. Six-Pack” Camshaft... [Re: JohnRR] #53618
03/01/08 12:11 PM
03/01/08 12:11 PM
New England
Q5_Ed Offline
Q5_Ed  Offline
New England
How is this cam in a 6pack stroker combo? 4 spd, 4.10
not big enough?
WANTED : ...A New Sponsor or Winning Lottery Ticket 69 A12 road runner ,Q5, post coupe, 4 speed, former Drag car restored to "Driver" condition in the early 90's, Showing some Patina. SS/E Track Record Holder 1980 10.40 @ 130mph
Re: A12 “Mr. Six-Pack” Camshaft... [Re: Q5_Ed] #53619
03/01/08 01:07 PM
03/01/08 01:07 PM
Madera, CA.
MowP4rsn Offline
MowP4rsn  Offline
Madera, CA.
Send him an email, he'll answer it. He replied then next day to my email.
mr6pk@hotmail.com
Re: A12 “Mr. Six-Pack” Camshaft... [Re: Q5_Ed] #53620
03/01/08 05:29 PM
03/01/08 05:29 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
not big enough?
not even close , its a STOCK LIFT replacement cam that will pass the PSMCDR certification process .
Re: A12 “Mr. Six-Pack” Camshaft... [Re: JohnRR] #53621
03/03/08 03:23 AM
03/03/08 03:23 AM
gretna, Ne
O
oem6pak Offline
oem6pak  Offline
O
gretna, Ne
ive run 2 of his cams in my 340's,worked well
Pure Stock Rules
Re: A12 “Mr. Six-Pack” Camshaft... [Re: MowP4rsn] #53622
03/19/08 01:36 PM
03/19/08 01:36 PM
Anonymous OP
Anonymous OP
Wow! Nearly two months later and the thread is still going strong! I had no idea!
Ken, thanks for the update on the cam. I haven’t bought the cam yet, so it’s cool to actually see pictures of what you get for your hard earned dough. Keep us posted on how it works out for you. BTW, What cams have you run before this?
Thanks again!
Re: A12 “Mr. Six-Pack” Camshaft... #53623
03/19/08 11:35 PM
03/19/08 11:35 PM
Madera, CA.
MowP4rsn Offline
MowP4rsn  Offline
Madera, CA.
Uh, the original 350hp cam...the engine has never been apart, and even now it starts up without a hint of smoke.
I will definitely let everyone know about how this works , once the engine is gone through and installed back in the car.
I just sent Demonsizzler $$ for a TQ and his fuel line set-up he's offering!! The fuel lines come with a fuel log/filter AND pressure gauge!
Re: A12 “Mr. Six-Pack” Camshaft... [Re: MowP4rsn] #53624
03/19/08 11:49 PM
03/19/08 11:49 PM
Anonymous OP
Anonymous OP
Ken,don't expect to hear much of a "rumble" with that 6-pack cam! With a 114 LSA,it should idle nice and smooth. I'm sure it'll make more power than the stocker though,even with the same lift as the stock cam! Good Luck with it!
Re: A12 “Mr. Six-Pack” Camshaft... #53625
03/20/08 06:04 PM
03/20/08 06:04 PM
Madera, CA.
MowP4rsn Offline
MowP4rsn  Offline
Madera, CA.
That's what I expect, perfect smooth engine at Idle, with maybe a bit of grunt when I get into it/more punch off line if I need it.
Folks will probably see my car and think it's a huge slug of a car, but I will know the real story.
Hmmm, maybe I should plan on doing the Silver State Classic once?
Re: A12 “Mr. Six-Pack” Camshaft... #53626
05/23/08 10:49 AM
05/23/08 10:49 AM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
Can someome post up Bob's phone number or PM it to me ? I want to place an order today.
-Thanks
Page 3 of 4 1 2 3 4
