Why cant I find the correct fuel pump? #534987
11/23/09 11:04 PM
11/23/09 11:04 PM
IL
hemiclone Offline OP
mopar addict
mopar addict
IL
Looking for a fuel pump for my 1970 440 Cuda, mopar part #2932799 If you order from napa it looks correct but the female thread on the pump is not large enough to fit my OEM 5/16" fuel line.
If you go on ebay there all advertising this pump to fit your car AND fuel lines...no way.
I already have returned the Napa pump and then returned the Ebay pump(guy charged me shipping both ways and a 15% restock..were still battling over this) and I still have no pump and a lot of frustration. Please Help!
Am I missing something here?
Re: Why cant I find the correct fuel pump? [Re: hemiclone] #534988
11/23/09 11:12 PM
11/23/09 11:12 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I believe you have to screw the 5/16" flare adapter into that pipe thread on pump.
Re: Why cant I find the correct fuel pump? [Re: buildanother] #534989
11/23/09 11:35 PM
11/23/09 11:35 PM
IL
mopar addict
mopar addict
IL
The 5/6" fuel Line has a 1/4" male MPT thread, The pump has a smaller female thread..approximately 1/8" FPT how do you fit these two together?
Re: Why cant I find the correct fuel pump? [Re: hemiclone] #534990
11/23/09 11:42 PM
11/23/09 11:42 PM
I drilled out & soldered in larger fittings into the 2 vertical "wells" in a stock pump to run 3/8 lines/fittings. Class rules require a stock "airtex" type SB pump EDIT regular lengths of parts store 3/8" inverted flare fuel line would not screw into the pump smaller female inverted flare fitting that was for 5/16" lines so I eventually decided to drill out the pump.
Re: Why cant I find the correct fuel pump? [Re: hemiclone] #534991
11/24/09 12:11 AM
11/24/09 12:11 AM
South Carolina
FM3_1970 Offline
FM3_1970  Offline
South Carolina
Does this look like it might work? From Year One web site:
AF422 Fuel line fitting, use with 440 engines to connect the 5/16" fuel line to the outlet side of the fuel pump. $7.95
Probably available cheaper elsewhere.
Re: Why cant I find the correct fuel pump? [Re: FM3_1970] #534992
11/24/09 12:34 AM
11/24/09 12:34 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
1/8" pipe to 5/16" flare,about $2.50 or less from NAPA and no shipping.
