removing trans dowel from rear of 440 block? #533469
11/22/09 01:43 PM
11/22/09 01:43 PM
Mooresburg, Tn
'72CudaRacer Offline OP
Mooresburg, Tn
What is the best way to remove alignment dowels from rear of 440 engine? I have a block that I'm preparing to use and one is missing. I was planning to take one from another block. Or can I just purchase a new one somewhere and install it? Anyone know where?
Thanks, Brian
Re: removing trans dowel from rear of 440 block? [Re: '72CudaRacer] #533470
11/22/09 01:56 PM
11/22/09 01:56 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Just knock it out,not hard to do,a hammer and punch works fine. You can make new dowels from bolt shanks or reuse one from another block.If you make them be sure to bevel the end like a stock dowel to easy tranny install.
Re: removing trans dowel from rear of 440 block? [Re: '72CudaRacer] #533471
11/22/09 01:59 PM
11/22/09 01:59 PM
AndyF Offline
AndyF  Offline
You can buy dowels from a dealer or Mopar Performance. Mopar dowels are not a standard size so don't try using dowels from a hardware store.
Best way to pull out dowel pins is to use a dowel pin puller. That will prevent them from being damaged.
Re: removing trans dowel from rear of 440 block? [Re: goldmember] #533472
11/22/09 04:11 PM
11/22/09 04:11 PM
Mooresburg, Tn
Mooresburg, Tn
The dowels are in a blind hole. They have to be pulled out.
Re: removing trans dowel from rear of 440 block? [Re: '72CudaRacer] #533473
11/22/09 05:11 PM
11/22/09 05:11 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I was thinking SB,sorry,I really should read the post more carefully.
Re: removing trans dowel from rear of 440 block? [Re: goldmember] #533474
11/22/09 06:35 PM
11/22/09 06:35 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
The last pair I removed. It was driled, tapped, thread in a long bolt and slide hammer it out.
My slide hammer was actually my vise grips on the bolt and my ball pein hammer.
Re: removing trans dowel from rear of 440 block? [Re: Magnum] #533475
11/22/09 07:36 PM
11/22/09 07:36 PM
IN
ahy Offline
ahy  Offline
IN
Vise grips and a hammer works well if they are stuck. Order a fresh set from Mancini or your store of choice.
Re: removing trans dowel from rear of 440 block? [Re: ahy] #533476
11/22/09 08:48 PM
11/22/09 08:48 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
One of my two were too stuck to use vise grips/hammer. I drilled it out one oversize at a time...
Neatest way I know of is to drill a small hole all the way through the pin. Tap the end for a small-thread zerk (grease) fitting, and hook up your grease gun. Several thousand psi from a few pumps of the gun and it'll pop right out. I couldn't find my small zerks though, so I had to do it the hard way!
-Charles
Re: removing trans dowel from rear of 440 block? [Re: DrCharles] #533477
11/22/09 10:14 PM
11/22/09 10:14 PM
N.E Indiana
repad Offline
super street
repad  Offline
super street
N.E Indiana
Great idea, I'm sure that will come in handy some day, thanks for passing that one on.
Re: removing trans dowel from rear of 440 block? [Re: DrCharles] #533478
11/22/09 10:29 PM
11/22/09 10:29 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
I like that drill and tap idea. Tap it 1/4" or 5/16" coarse, thread in a short bolt, and use a claw hammer to lever it out. It should be reusable and easily removed later if you want.
Cory
Re: removing trans dowel from rear of 440 block? [Re: ahy] #533479
11/22/09 10:34 PM
11/22/09 10:34 PM
Mooresburg, Tn
Mooresburg, Tn
I guess I was over thinking this. One is missing, I just need to get another one. I was thinking just take one out of the other engine, but I'll just order one next time I order parts. But some very good tips anyway.
Thanks, Brian
