'71 Charger broadcast sheet questions #529598
11/18/09 01:30 AM
11/18/09 01:30 AM
Missouri
MOBodyman Offline OP
Missouri
I'm trying to help someone decode their broadcast sheet. Where can I find the info? Particularly interested in which wheels originally came on the car. Line 4 'wheels' section is as follows;
ROAD 52
COLOR TX8
SPARE 59
WHEEL COVER 24
Line 12 appears to have a 2 in the 'road wheels' section with a 1 in the box below it.
On another note, written with what looks like a marker at the bottom of the sheet below that is a 23 with D6X9 below it.
TIA,
Dallas
2012 Rallye Redline Challenger, 1st new car!
2010 Ram 1500 4wd HEMI-hauler
2014 Dodge Dart-gas saver
4 projects and a bunch of parts cars, losing interest since buying the Challenger lol
1969 Dodge Coronet 500-'gonna fix 'er up someday!'
Re: '71 Charger broadcast sheet questions [Re: MOBodyman] #529599
11/18/09 01:33 AM
11/18/09 01:33 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
W21 - Rallye wheels.
Black spare.
Re: '71 Charger broadcast sheet questions [Re: Alaskan_TA] #529600
11/18/09 11:22 AM
11/18/09 11:22 AM
Missouri
Missouri
Thanks for the reply. Would that be 14" wheels?
The car is a WS23 so I assume the '23' written at the bottom refers to this. What does the 'D6X9' refer to?
Thanks again,
Dallas
Re: '71 Charger broadcast sheet questions [Re: MOBodyman] #529601
11/18/09 11:42 AM
11/18/09 11:42 AM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
dallas hey.. D6X9 is deluxe int black..whats the tire code? if it starts with a T its 14" U=15" good luck hows things? dan
Re: '71 Charger broadcast sheet questions [Re: ph23vo] #529602
11/18/09 11:56 PM
11/18/09 11:56 PM
Missouri
Missouri
Hey Dan,
Thanks for the additional info. The tire code is T46, I believe.
Things are going pretty good. I've had quite a bit of family stuff to take care of, but the shop has been pretty busy all summer, and I'm still trading and working on some of my old Mopars.
I hope all is well with you. Are you making any progress on any of your projects?
Thanks,
Dallas
