Post deleted by Defbob
[Re: Hunted Duck]
#528307
11/16/09 05:11 PM
11/16/09 05:11 PM
Re: Are Stainless bolts strong enough to hold motor plate?
#528313
11/16/09 07:57 PM
11/16/09 07:57 PM
Challenger 1
Cincinnati, Ohio
Yes, as long as your engine makes less than 4,000 hp.
For sure.
[Re: hemi_doug]
#528316
11/16/09 08:05 PM
11/16/09 08:05 PM
#528317
11/16/09 08:08 PM
11/16/09 08:08 PM
Challenger 1
Cincinnati, Ohio
On my old (now HEMIFRED's) Duster, I had a one piece motor plate with a Meziere water pump, held together by 6 stainless steel socket cap screws from Lowe's. Block is an iron Megablock. Hung together with no issues for 5 years. And than blown Hemi was heavy!
I held my blown 3000 HP hemi in my TAD with less!!
It's only a water pump and motor plate, it ain't like were talking a rod or something!
[Re: CrAzYMoPaRGuY]
#528319
11/16/09 08:30 PM
11/16/09 08:30 PM
dartman366
Mt. Vernon, Ohio
I'm one of the few who aren't a fan of stainless steel bolts PERIOD! Into an iron block sure, but involve aluminum or a stainless steel nut in any way.... and I run, and don't look back!!!!!!!
white lithium grease or never sieze will help solve that problem, we use sst fastner's every day, mostly aircraft quality 316/316L grade , some 304 grade but the material is softer and has less chromium and will actually rust(corrode).
[Re: Dos Snails]
#528321
11/16/09 10:11 PM
11/16/09 10:11 PM
Posts: 8,165 Left Coast
BobR
Left Coast
I've twisted off a few SS bolts, Anything from a hardware store scares the crap out of me! I have to use SS hardware on my boat, I always thought SS was hard metal until now..
Just hard to cut because it work hardens. Use anti-seize with any bolt that screws into aluminum not just SS. SS bolt will gall onto a SS nut so anti-seize or loc-tite is a good idea there too.
[Re: CrAzYMoPaRGuY]
#528322
11/16/09 10:36 PM
11/16/09 10:36 PM
[Re: Hunted Duck]
#528323
11/16/09 11:50 PM
11/16/09 11:50 PM
Posts: 1,093 Long Beach, CA
Mike Swann
Long Beach, CA
In shear and tensile strength, a grade 5 bolt is 3 x stronger than the same sized SS bolt at the hardware store. a Grade 8 is 4 x stronger.
8.30's @3400 lbs
[Re: 340RICK]
#528326
11/17/09 08:50 AM
11/17/09 08:50 AM
Posts: 1,163 Newark, OH
Hunted Duck
Newark, OH
hey Jeff all ARP 12 point polished SS.....Cuz there purty
They sure are Rick
#528327
11/17/09 09:53 AM
11/17/09 09:53 AM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
On my old (now HEMIFRED's) Duster, I had a one piece motor plate with a Meziere water pump, held together by 6 stainless steel socket cap screws from Lowe's. Block is an iron Megablock. Hung together with no issues for 5 years. And that blown Hemi was heavy!
If you had an ALUMINUM block would you have still installed the stainless hardware? I've seen so many galled aluminum parts- even with anti-seize attempts- with stainless fasteners I am now officially a scare-D-cat.
Apply Never-Seize liberally on the threads. Better yet, use studs instead of bolts. Drive them in slowly to reduce heat and friction.
What does "galling" mean??
[Re: Hunted Duck]
#528328
11/17/09 10:06 AM
11/17/09 10:06 AM
Posts: 2,031 Florida
StewartP
Mopar Vintage Picture Guy
[Re: StewartP]
#528329
11/17/09 10:57 AM
11/17/09 10:57 AM
domingo
EL Master
EL Master
Lima, Peru
Titanium studs
Talk about overkill.
[Re: Stanton]
#528331
11/18/09 02:51 AM
11/18/09 02:51 AM
Posts: 2,932 Finalnd, Perkele
jyrki
Finalnd, Perkele
They used to attach the engines in top fuelers with hose clamps on hte frame rails; there isn't that much force that it would require anything special. I have used Stainless ARP bolts about everywhere in our aluminum engine. Neverhad galling problems, but they tend to loosen every once in a while, mainly intake/exhaust/oil pan bolts. Don't know if that's because of the material or something else though.
Plynouth VIP '67 TT IC EFI
