Re: 360 performance
[Re: dustergirl340]
#527534
01/06/10 11:16 AM
01/06/10 11:16 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
How much does a '72 Satellite weigh anyway? My supposedly 'light' '73 A-body weighs 3,500 pounds with me in it. I can't see a Satellite weighing that much more.
A 340 small block propels my fat Duster just fine.
the motor is a runner out of my 5th ave, which w/o me is 3950 lbs....granted I sold it to him without the eddie RPM air gap and eddie 600, and IIRC he's got a performer and I think either a 600 carter AFB or 600 holley....
with a MP166k converter and 3.55's, it would light up the tires of my boat (255/50R17's) and keep up with a stock LX 300 hemiC AWD from a roll....
just get the dang thing in and running already!
Re: 360 performance
[Re: patrick]
#527536
01/09/10 05:05 AM
01/09/10 05:05 AM
Posts: 580 Detroit,Michigan USA!
erick72
lol i just got it all in as off 2 hours ago
Re: 360 performance
[Re: mark7171]
#527543
01/09/10 05:13 PM
01/09/10 05:13 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
4 dr, 4spd, 323" 3.23 geared, A body has the 340 hp cam .429/.444" and shaved 1.88/1.60" 318 heads, s
14 mpg city/15 highway.
Only way that a 318 had those heads is if someone put them on or the engine was a 318 4 barrel engine which used the 360 heads. Other wise they are 340/360 heads not std. 318 heads.
Re: 360 performance
[Re: erick72]
#527544
01/09/10 09:34 PM
01/09/10 09:34 PM
TMP66
i know i know ive asked before. but i got a 360 im ready to put in my 72 roadrunner/satellite and i keep getting told "oh that car is way to heavy for that baby engine" or that thing wont be fast enough"
HONESTLY ANY ONES INPUT WANTED.
The best input I can think of is...if you like small blocks and have a budget/goal of what you can afford and want to do, go for it. Do what you want and screw the unsolicited opinions of others.
Re: 360 performance
[Re: MonGoo$e]
#527547
01/10/10 11:07 PM
01/10/10 11:07 PM
DaytonaTurbo
Manitoba, Canada
I would have laid the headers in the engine bay before install.
I doubt it'll be much of an issue. I put the headers in my 74 after dropping in the 440, just pulled up on the motor a bit with the engine jack and they slid right in. With a little 360 he will have a lot more room to spare.
Re: 360 performance
[Re: erick72]
#527550
01/11/10 08:49 AM
01/11/10 08:49 AM
patrick
Grand Haven, MI
stuffing that bad boy in. do you guys think i can get headers in from under?
when I put it in my 5th, I put the headers in first, held them up and out of the way with bungee cords, then dropped the engine in......of course, I also but the tranny in after the motor was in....
Re: 360 performance
[Re: erick72]
#527552
02/22/10 02:14 AM
02/22/10 02:14 AM
RapidRobert
see if the plugs are clean/see if the plugs are getting fire/fill up the carb bowl vents w gas until the AP give a full squirt/reluctor even w magnet w dampener @10 before on #1 compression
Re: 360 performance
[Re: RapidRobert]
#527553
02/22/10 09:13 AM
02/22/10 09:13 AM
patrick
Grand Haven, MI
if you haven't touched the distributor since you picked it up from me, make sure I didn't accidentally put in in 180 degrees out...
