Pinion angle? #525727
11/14/09 12:45 PM
11/14/09 12:45 PM
KY
juicedcuda Offline OP
KY
I am setting the pinion angle on my car, it is a leaf spring car, so I am looking for 7* nose down. My angle finder is reading 3* on the tail end of the drive shaft and 10* on the pinion nose down. This is my 7* correct?
1970 Plymouth 'Cuda 1970 Plum Crazy "Gold Duster" 1973 Gold Duster
Re: Pinion angle? [Re: juicedcuda] #525728
11/14/09 12:53 PM
11/14/09 12:53 PM
If there is a V at the pinion yoke and the driveshaft then yes that is the angle, if it is an inverted V(I can't make that sign on this keyboard ) then make it a so the driveshaft is the left side of the V and the pinion yoke is the the right sid of the V, both pointing at the bottom of the V I really hope this makes sense BTW, if the car vibrates under WOT or on deacceleration try 5 degrees difference next time Some cars will vibrate at 7 and some don't I think it depends on the U joint size used.
Re: Pinion angle? [Re: juicedcuda] #525729
11/14/09 01:04 PM
11/14/09 01:04 PM
Witness Protection Program
Kudakidd Offline
Kudakidd  Offline
Put your angle finder on the yoke. It should be 5-7* down.
Re: Pinion angle? [Re: Kudakidd] #525730
11/14/09 01:11 PM
11/14/09 01:11 PM
KY
KY
that's what I posted, with the angle finder on the yoke it is 10* down. But you have to subtract the three out for the drive shaft. I wanted to make sure I was thinking correctly. My setup is as cab described, a "v".
Re: Pinion angle? [Re: juicedcuda] #525731
11/14/09 01:15 PM
11/14/09 01:15 PM
Q
Quicktree Offline
Quicktree  Offline
Q
do a search on pinion angle, that will answer all of your questions
Re: Pinion angle? [Re: juicedcuda] #525732
11/14/09 02:21 PM
11/14/09 02:21 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
A true 7 degree negative pinion angle will usually bind.
I recommend 5 degrees, maximum.
Make the pinion parallel to the transmission as a baseline, then roll the pinion downward 4 degrees and weld the perches. This will yield a true 4 degree negative pinion angle.
Re: Pinion angle? [Re: DoctorDiff] #525733
11/14/09 02:40 PM
11/14/09 02:40 PM
Queens, New York
Harley Offline
Harley  Offline
Queens, New York
I put a Dana in my car and went for a ride and it had a bad vibration when I decelerated. I checked pinion angle and found it to be 10 degrees nose down. I shimmed it to 3 degrees nose down and it was fine.
Re: Pinion angle? [Re: DoctorDiff] #525734
11/14/09 04:16 PM
11/14/09 04:16 PM
no more than 5 degrees nose down regardless.
