4.500 BB Engine Blocks????????
#525267
11/13/09 08:11 PM
11/13/09 08:11 PM
Been out of the loop for a while on BB Engine Blocks. It appears that I now need one and if I remember correctly about 8-10 months ago you could buy about 12 different versions of a BB engine block from world products. They had standard bore, 4.500 bore, cast iron, aluminum, street versions, race version.......I think I remember them seeing something about a composite version. Now you look around and there is nothing....What happened?????? Looking for cast Iron
Re: 4.500 BB Engine Blocks????????
[Re: blownzoom440]
#525270
11/13/09 09:43 PM
11/13/09 09:43 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Hey Lane I havent heard from you in a long time...You still work for Best Machine Racing? Did you finish that Dart chassis? Last time I seen it, it was getting some updated chassis work... Later Bob From Ky
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Cab_Burge]
#525272
11/13/09 11:53 PM
11/13/09 11:53 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
if its NA don't use aluminum we know that [Edited by Moparts - Family Friendly Site - Keep it clean] don't work
BB, TT5,Procharged 3300lb Street Car 4.79/154
#525274
11/14/09 07:10 AM
11/14/09 07:10 AM
What I am looking for is Cast Iron, 4.500 Bore, Lifter bores bushed, Standard or raised cam block for 55mm cam, cross bolted mains. World used to have all their part numbers on thier web site but now it just show alum??
Did they run out of supply on the cast iron stuff. Really wanted their 4.500 cast iron race version. Just trying to figure out where all this info went.
#525275
11/14/09 12:27 PM
11/14/09 12:27 PM
Posts: 43,118 Bend,OR USA
Cab_Burge
Call them on Monday, or even today to find out the straight scoop
[Re: Cab_Burge]
#525276
11/14/09 05:18 PM
11/14/09 05:18 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Here's the scoop to some degree on whats going on with the cast iron Wedge blocks. Mopar ( go figure) actually waits till they get a number of backorders or their "system" sees a demand built up for a blcok order. They need to order them 100 at a time, and they also include the Hemi blocks into this "ordering process". Since there are approx 75-80 Hemi blocks in the system at the moment, there is no rush for them to order 100 blocks of any configuration. Until the 80 Hemi blocks get depleted to some degree, they wont be ordering more Wedge blocks.
I have been trying to get a straight answer from World as well, but no real answers.
World has a new program they are just releasing to dealers ( of all brands) so that is weighing into it as well. It will be different than anything that has been tried before in the business. Will have to wait and see how it works out.
That is the straight scoop, not what anyone wants to hear, but pretty up to date information.
RIP Monte Smith
[Re: B1Fish540]
#525277
12/02/09 10:38 AM
12/02/09 10:38 AM
Posts: 627 IN
BIG BEAR
IN
I think Koleno has a sale going on theirs. Arguably the best one out there.
Thanks Chester
[Re: CompWedgeEngines]
#525278
12/02/09 11:05 AM
12/02/09 11:05 AM
Posts: 17,840 S.E. Michigan
ZIPPY
S.E. Michigan
Todd, thanks for posting that info so accurately.
I'd like to add: the above only applies to Mopar part numbered blocks sold through an authorized Mopar Performance Parts dealer.
It has nothing to do with World's business, or World's in-house part numbers only sold through WP.
If you can't get a 4.500 "race" configuration wedge block (dual bellhousing patterns, etc)....since that configuration is not even offered by Mopar, it needs to be discussed with WP.
Mopar owns the tooling, but Mopar has nothing to do with race block production volume because Mopar does not sell that configuration, and has no active part numbers for that configuration.
[Re: Diablo]
#525281
12/02/09 12:24 PM
12/02/09 12:24 PM
Posts: 627 IN
BIG BEAR
IN
If you can't get a world one right away go with the Koleno one! Much better block in mind in the first place and well priced.
Now there is a guy that knows what he is talking about!!!
[Re: ZIPPY]
#525282
12/02/09 12:27 PM
12/02/09 12:27 PM
Posts: 627 IN
BIG BEAR
IN
Thanks for all the info guys. If anyone knows why they need 100 blocks to be ordered first, we do.
[Re: Al_Alguire]
#525286
12/02/09 01:45 PM
12/02/09 01:45 PM
Posts: 2,915 A shed in England
Tig
A shed in England
Yeah we all know aluminum NA engines are dogs
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
#525288
12/03/09 07:19 PM
12/03/09 07:19 PM
Posts: 627 IN
BIG BEAR
IN
We may have a few left with the lifter bores bushed,(I'll have to check)- if you are interested.
[Re: tntmachine]
#525293
12/04/09 11:18 AM
12/04/09 11:18 AM
bigtimeauto
Trophy Winner
Trophy Winner
Aluminum, cast, CGI, World, Indy, Koleno, Mopar: which is the best way to go for a all out race motor?
All out NA? CGI but you can't get regular ones, cast, then aluminum.
but i don't know anything.
[Re: tntmachine]
#525295
12/04/09 12:00 PM
12/04/09 12:00 PM
Posts: 19,360 Las Vegas
Al_Alguire
Las Vegas
Aluminum is not the best way to go if you are truly trying to build an all out pedal to the metal max HP deal, look at Pro Stock and Comp and see what they use. Having said that I am willing to give up the 20HP+- I could be loosing by using aluminum for the sake of less weight, and repairability. My junk is aluminum(KB)and made 2+hp per cube.
[Re: Al_Alguire]
#525296
12/04/09 12:05 PM
12/04/09 12:05 PM
Posts: 627 IN
BIG BEAR
IN
Aluminum is not the best way to go if you are truly trying to build an all out pedal to the metal max HP deal, look at Pro Stock and Comp and see what they use. Having said that I am willing to give up the 20HP+- I could be loosing by using aluminum for the sake of less weight, and repairability. My junk is aluminum and made 2+hp per cube.
I am so curious as to why everyone thinks that iron is so unrepairable. Beautiful car by the way
[Re: BIG BEAR]
#525297
12/04/09 12:26 PM
12/04/09 12:26 PM
Posts: 2,286 Hamilton,Ont
72chrgrally
Hamilton,Ont
BigBear any word on a low deck casting? Steve
Sorry for the hijack Lane!
Photobucket sucks
[Re: 72chrgrally]
#525298
12/04/09 12:33 PM
12/04/09 12:33 PM
Posts: 627 IN
BIG BEAR
IN
Don't worry bud, she's acomin! So start saving now
[Re: Al_Alguire]
#525300
12/04/09 01:03 PM
12/04/09 01:03 PM
Posts: 627 IN
BIG BEAR
IN
It is not that cast is not repairable. The cost and availability make it not a viable option for many. I had a windowed Hemi block from when my old Hemi let go. I was going to have it repaired as it had all the oiling mods, lifter bushings etc done to it. However by the time I paid the cost to have it repaired out here I was 2/3 the way to a new block so I went that route instead. As for fixing the aluminum block it is FAR easier to find a competent place to have the work done. FWIW I had a Mega block fixed out here once, by the tim I paid to have the block welded, put in a the two sleeves it needed and paid for the misc machining required i had an additional $2K in it. Hardly worth the effort these days when I can pick up a World block for $2600. Maybe for someone in the casting business having cast repaired is a simple process but for us pee ons in the world it aint so easy, cost affective or worth the effort. I am just a simple bracket racer and to me having something a bit lighter that can be easily fixed is worth the extra $$. I would have to ask what does a Koleno block cost similar to my KB. It has 55MM cam with roller bearings,and bushed lifter bores, just curious what this set up would run me for a Koleno? BTW Just my on the subject.
BTW thanks for the kudos on the tank.
Well yes, you are right, aluminum is probably easier to weld on. However if you are unlucky enough to "blow up" your block, depending on the damage of course, wouldn't you hesitate putting your left over internals on a repaired block and that it doesn't happen again.(just my thought). You are also right about farming the weld repair job out, it is expensive, even for us well to do billionairs
As for the 55mm cam blocks, we do have a few left.None of them now have lifter bushings in them but I'm sure we could work something out on that. As they are now, it would be no additional cost.
[Re: bigtimeauto]
#525303
12/04/09 07:42 PM
12/04/09 07:42 PM
Posts: 627 IN
BIG BEAR
IN
CGI is tuff stuff but I don't think anyone will manufacture it it takes to long to machine and to perfect it, you would need different tooling than grey iron, and by the looks of it no one has the money to invest.
[Re: BIG BEAR]
#525304
12/04/09 07:59 PM
12/04/09 07:59 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Unless I missed something it looks like you're not but a 1/2 hour or so from Koffel's Place Mi location.
4300 Haggerty Rd. Walled Lake MI. 48390
Koffel's Place
Could save you some serious coin on shipping and the Koffel's are great people to deal with.
[Re: BIG BEAR]
#525306
12/04/09 10:09 PM
12/04/09 10:09 PM
Posts: 3,441 Mo.
supercomp
Mo.
Why did you quit bushing the lifter bores? We use pushrod oiling so that means another $400.00 for a block.
[Re: supercomp]
#525307
12/04/09 10:13 PM
12/04/09 10:13 PM
Posts: 627 IN
BIG BEAR
IN
?????? I'm not sure I know what you mean
[Re: supercomp]
#525311
12/04/09 11:18 PM
12/04/09 11:18 PM
Posts: 627 IN
BIG BEAR
IN
[Re: supercomp]
#525313
12/05/09 12:09 PM
12/05/09 12:09 PM
Posts: 16,923 NC
440Jim
NC
I vote bushed. Won't hurt even if you don't need them, but if you do they are there. As more people build more hp they need indivigual shaft rockers.(pushrod oiling)
Help me understand by clarifying that. I thought for pushrod oiling you need oil to the lifter, so unbushed should work? And if you put solid bushings in (without an oil hole), then no oil would go to the lifter and you couldn't pushrod oil.
1) Unbushed 2) Solid bushing (no oil hole) 3) Bushings with a small oil hole.
[Re: 72chrgrally]
#525314
12/06/09 12:07 PM
12/06/09 12:07 PM
Posts: 627 IN
BIG BEAR
IN
Alright my penny jar has a purpose! Please keep us up to date on this. Thanks! Steve [/quote
[Re: 440Jim]
#525315
12/06/09 08:51 PM
12/06/09 08:51 PM
Posts: 627 IN
BIG BEAR
IN
I believe your right Jim. You would need to oil the lifters in order to get oil thru the push rod.
[Re: BIG BEAR]
#525316
12/06/09 11:11 PM
12/06/09 11:11 PM
Posts: 3,441 Mo.
supercomp
Mo.
to much oil without bushing and small hole and lack of oil pressure.
[Re: supercomp]
#525317
12/07/09 08:54 AM
12/07/09 08:54 AM
Posts: 627 IN
BIG BEAR
IN
What about restricting the oil gallies?
[Re: supercomp]
#525320
12/07/09 10:24 AM
12/07/09 10:24 AM
Posts: 627 IN
BIG BEAR
IN
Ask around and see what the big builders think. If it doesn't raise the price I think they will vote for bushings because they are better in a high lift race engine.
If you ADD anything, it will always cost more. The key is to keep to cost as low as possible to the end user. More than likely all the blocks that we cast in the future will have the bushings installed, however you may see a slight price increase because of it.
[Re: blownzoom440]
#525321
12/07/09 10:26 AM
12/07/09 10:26 AM
Posts: 627 IN
BIG BEAR
IN
my block #33 came unbushed and i will be restricting the oil at the back of the block.i only use a 650 lift roller.milodon single line,melling HV pump.20/50 oil.
Thanks Metal Storm, We were wondering what number you had. Please keep us informed of the build.
