4.500 BB Engine Blocks????????
#525267
11/13/09 08:11 PM
11/13/09 08:11 PM
Been out of the loop for a while on BB Engine Blocks. It appears that I now need one and if I remember correctly about 8-10 months ago you could buy about 12 different versions of a BB engine block from world products. They had standard bore, 4.500 bore, cast iron, aluminum, street versions, race version.......I think I remember them seeing something about a composite version. Now you look around and there is nothing....What happened?????? Looking for cast Iron
Re: 4.500 BB Engine Blocks????????
[Re: blownzoom440]
#525270
11/13/09 09:43 PM
11/13/09 09:43 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Hey Lane I havent heard from you in a long time...You still work for Best Machine Racing? Did you finish that Dart chassis? Last time I seen it, it was getting some updated chassis work... Later Bob From Ky
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Cab_Burge]
#525272
11/13/09 11:53 PM
11/13/09 11:53 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
if its NA don't use aluminum we know that [Edited by Moparts - Family Friendly Site - Keep it clean] don't work
BB, TT5,Procharged 3300lb Street Car 4.79/154
#525274
11/14/09 07:10 AM
11/14/09 07:10 AM
What I am looking for is Cast Iron, 4.500 Bore, Lifter bores bushed, Standard or raised cam block for 55mm cam, cross bolted mains. World used to have all their part numbers on thier web site but now it just show alum??
Did they run out of supply on the cast iron stuff. Really wanted their 4.500 cast iron race version. Just trying to figure out where all this info went.
#525275
11/14/09 12:27 PM
11/14/09 12:27 PM
Posts: 43,099 Bend,OR USA
Cab_Burge
Call them on Monday, or even today to find out the straight scoop
[Re: Cab_Burge]
#525276
11/14/09 05:18 PM
11/14/09 05:18 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Here's the scoop to some degree on whats going on with the cast iron Wedge blocks. Mopar ( go figure) actually waits till they get a number of backorders or their "system" sees a demand built up for a blcok order. They need to order them 100 at a time, and they also include the Hemi blocks into this "ordering process". Since there are approx 75-80 Hemi blocks in the system at the moment, there is no rush for them to order 100 blocks of any configuration. Until the 80 Hemi blocks get depleted to some degree, they wont be ordering more Wedge blocks.
I have been trying to get a straight answer from World as well, but no real answers.
World has a new program they are just releasing to dealers ( of all brands) so that is weighing into it as well. It will be different than anything that has been tried before in the business. Will have to wait and see how it works out.
That is the straight scoop, not what anyone wants to hear, but pretty up to date information.
RIP Monte Smith
[Re: B1Fish540]
#525277
12/02/09 10:38 AM
12/02/09 10:38 AM
Posts: 627 IN
BIG BEAR
IN
I think Koleno has a sale going on theirs. Arguably the best one out there.
Thanks Chester
[Re: CompWedgeEngines]
#525278
12/02/09 11:05 AM
12/02/09 11:05 AM
Posts: 17,838 S.E. Michigan
ZIPPY
S.E. Michigan
Todd, thanks for posting that info so accurately.
I'd like to add: the above only applies to Mopar part numbered blocks sold through an authorized Mopar Performance Parts dealer.
It has nothing to do with World's business, or World's in-house part numbers only sold through WP.
If you can't get a 4.500 "race" configuration wedge block (dual bellhousing patterns, etc)....since that configuration is not even offered by Mopar, it needs to be discussed with WP.
Mopar owns the tooling, but Mopar has nothing to do with race block production volume because Mopar does not sell that configuration, and has no active part numbers for that configuration.
[Re: Diablo]
#525281
12/02/09 12:24 PM
12/02/09 12:24 PM
Posts: 627 IN
BIG BEAR
IN
If you can't get a world one right away go with the Koleno one! Much better block in mind in the first place and well priced.
Now there is a guy that knows what he is talking about!!!
[Re: ZIPPY]
#525282
12/02/09 12:27 PM
12/02/09 12:27 PM
Posts: 627 IN
BIG BEAR
IN
Thanks for all the info guys. If anyone knows why they need 100 blocks to be ordered first, we do.
[Re: Al_Alguire]
#525286
12/02/09 01:45 PM
12/02/09 01:45 PM
Posts: 2,915 A shed in England
Tig
A shed in England
Yeah we all know aluminum NA engines are dogs
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
