Where is turn signal relay on a '68 Coronet #523600
11/11/09 06:47 PM
11/11/09 06:47 PM
Belle Mead, NJ
65Frank Offline OP
super street
65Frank  Offline OP
super street
Belle Mead, NJ
I can hear the hazard relay clicking near the ashtray, but of course since the turn signals aren't working, I can't hear their relay and I can't see it anywhere looking under the dash. Where the heck is it?
Re: Where is turn signal relay on a '68 Coronet [Re: 65Frank] #523601
11/11/09 07:01 PM
11/11/09 07:01 PM
N.E Indiana
repad Offline
super street
repad  Offline
super street
N.E Indiana
If you mean the flasher, it should be located in a "cup" just under the guage cluster.
Re: Where is turn signal relay on a '68 Coronet [Re: repad] #523602
11/12/09 10:01 AM
11/12/09 10:01 AM
Belle Mead, NJ
65Frank Offline OP
super street
65Frank  Offline OP
super street
Belle Mead, NJ
Thanks. To the left or right of the column? And do I need to drop the column to get to it?
Re: Where is turn signal relay on a '68 Coronet [Re: 65Frank] #523603
11/12/09 10:07 AM
11/12/09 10:07 AM
N.E Indiana
repad Offline
super street
repad  Offline
super street
N.E Indiana
iirc it's just to the left of the column. You don't have to drop the column or remove anything but it helps to have someone with small hands.
Re: Where is turn signal relay on a '68 Coronet [Re: repad] #523604
11/12/09 12:31 PM
11/12/09 12:31 PM
Belle Mead, NJ
65Frank Offline OP
super street
65Frank  Offline OP
super street
Belle Mead, NJ
Thanks, found it. It was hiding behind the under dash radio installed by the previous owner
Re: Where is turn signal relay on a '68 Coronet [Re: 65Frank] #523605
11/12/09 01:33 PM
11/12/09 01:33 PM
N.E Indiana
repad Offline
super street
repad  Offline
super street
N.E Indiana
If you found it under the radio, it may be the flasher for the e-switch. There are two flashers, one for the 4way and one for the turn signals.
