Re: Cam/Torque converter question
[Re: moparrulzzz]
#522898
11/10/09 10:55 PM
11/10/09 10:55 PM
Posts: 1,454 oklahoma
forphorty
oklahoma
Simply put, the more radical the cam, the less power it will make at lower rpm.The more Radical the cam, the more stall speed needed. When it comes to diameter, usually the smaller converter will be more efficient than a larger one for a given stall speed. as an example: A 9.5 inch 4000 stall will probably be more efficient than a 10 inch 4000 stall. When choosing a converter, a lot of things should be taken into account, such as car weight, gear ratio,etc. Your best bet is to pick a reputable company and call them. Give them all the pertinent info on your car and its intended use and they can make a suggestion.
