I just used some Mopar engine enamel on my 440. I didn't know about enamel recoat windows until after i painted and was looking around on the net.
Basically i did two thin coats coats one day and then 2 thin coats the next day 12 hours later. I didn't know you were supposed to do it all in an hour or wait 7 days for it to cure before coating again.
Now less then 24 hours later the paint is dry to the touch but i can stick my fingernail in it.
Will this ever cure now or am i screwed?
Thanks Mike
