Mini Tub Dart and Scamp ?? #521737
11/09/09 08:33 PM
11/09/09 08:33 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
What the widest tire you can fit?
Re: Mini Tub Dart and Scamp ?? [Re: Scamp408] #521738
11/09/09 08:48 PM
11/09/09 08:48 PM
Manassas, VA USA
Scamp451 Offline
Scamp451  Offline
Manassas, VA USA
On my '73 Scamp, I fit a Hoosier 29 X 12 with a 15 X 10 rim with no problem. I did roll the top of wheel opening lip upward. I believe that Hoosier was a 13.7 section width, but you might get away with more but will be tight. That diameter tire gave me about 1/2 inch from the lower front wheel opening, and had to trim the front of the inner wheel due to clearance concerns. Also depends on how low or high you want the car to ride...the lower you go, the more ostructions there are to deal with.
I think the max amount of space you can get from the outer frame rail (with no undercoating ) to the outer quarter with the lip rolled up is pretty darn close to 15" on the Scamps, Darts, and Valiants I have measured.
Re: Mini Tub Dart and Scamp ?? [Re: Scamp451] #521739
11/09/09 09:50 PM
11/09/09 09:50 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
On a Dart you really need to stretch the opening a little to get a tall tire on there.
Re: Mini Tub Dart and Scamp ?? [Re: Scamp408] #521740
11/09/09 09:54 PM
11/09/09 09:54 PM
colorado
chargermop Offline
chargermop  Offline
colorado
I would say the bigest tire would 29-12.5-15 thats all I could fit with the rearend moved back 1" . No cuting other than the mini-tub and rolling the lip.........
Re: Mini Tub Dart and Scamp ?? [Re: chargermop] #521741
11/09/09 09:56 PM
11/09/09 09:56 PM
colorado
chargermop Offline
chargermop  Offline
colorado
one more
Re: Mini Tub Dart and Scamp ?? [Re: chargermop] #521742
11/09/09 09:57 PM
11/09/09 09:57 PM
colorado
chargermop Offline
chargermop  Offline
colorado
last one lol
Re: Mini Tub Dart and Scamp ?? [Re: chargermop] #521743
11/09/09 10:02 PM
11/09/09 10:02 PM
oregon
greendart408 Offline
oregon
Mine, 29.5x11.5s on a 11in wheel.
Re: Mini Tub Dart and Scamp ?? [Re: greendart408] #521744
11/09/09 10:12 PM
11/09/09 10:12 PM
oregon
oregon
2
Re: Mini Tub Dart and Scamp ?? [Re: greendart408] #521745
11/09/09 10:23 PM
11/09/09 10:23 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Thanks Guys
I already have the rear moved back 1in but I have come to a problem area. I was looking in the trunk and found if I put the tubs to the frame rail I will have to cut about 3/4-1/2in off my 6x6in plate for the roll bar.To much malted hopps that night I guess. So if I leave the plates alone I could only move the tubs to the frame spot-weld flange.
Re: Mini Tub Dart and Scamp ?? [Re: Scamp408] #521746
11/10/09 08:49 AM
11/10/09 08:49 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Are you woried about the plate being smaller than 6x6 and not being legal? You can add a additonal piece to the vertical outside of the frame rail to increase the size of the plate. The rule doesn't state that the 6x6 has to be flat. We did this on "Dizusters" car. I'm sure there are pictures in the archives of his mini tub and cage.
Doug
Re: Mini Tub Dart and Scamp ?? [Re: dvw] #521747
11/10/09 10:17 AM
11/10/09 10:17 AM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
I just dont want any problems with tech. I was just wondering if the extra 1/2in make the diff on putting some meats on.
Re: Mini Tub Dart and Scamp ?? [Re: Scamp408] #521748
11/10/09 10:35 AM
11/10/09 10:35 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I have 315/60/15's in mine... It's a 71
Mopar Performance
Re: Mini Tub Dart and Scamp ?? [Re: moparniac] #521749
11/10/09 12:01 PM
11/10/09 12:01 PM
Utah
dragnduster Offline
dragnduster  Offline
Utah
Do you have any pics of it?
Re: Mini Tub Dart and Scamp ?? [Re: dragnduster] #521750
11/10/09 12:45 PM
11/10/09 12:45 PM
Richmond , Virginia
BEEQUIK Offline
BEEQUIK  Offline
Richmond , Virginia
my 68 dart had 30x13.50 ET Streets on it. It was mini-tubbed but used an aftermarket tub not the factory one.Also the qtrs were stretched 3"
Re: Mini Tub Dart and Scamp ?? [Re: BEEQUIK] #521751
11/10/09 01:22 PM
11/10/09 01:22 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Right now I have a 28x11 in the stk tub but rear end moved back 1in. I still have some room but was thinking 13 or 13.5 drag radial.
Re: Mini Tub Dart and Scamp ?? [Re: Scamp408] #521752
11/10/09 01:41 PM
11/10/09 01:41 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Is it possible to fit a 31" tyre with an aftermarket tub, sorry to hijack but i thought a bit extra info wouldn't hurt.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Mini Tub Dart and Scamp ?? [Re: dragnduster] #521753
11/10/09 04:27 PM
11/10/09 04:27 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
yea several .. I'll post later tonight...
Mopar Performance
Re: Mini Tub Dart and Scamp ?? [Re: Scamp408] #521754
11/10/09 06:08 PM
11/10/09 06:08 PM
Super Scamp Offline
Super Scamp  Offline
71 Scamp with Mopar mini tub setup. Tubs to the frame wells outer upper lip rolled a bit.
I was running 15x12 with 3 1/2 B/S On Hoosier (slicks) 29"x12"x 15 It's the biggest you can run without moving in the frame wells and cutting the quarter panel or moving the rear.
Going to fast now putting in Dana 4-link setup.
Just One Man's Opinion Mopar Mafia Racing
Re: Mini Tub Dart and Scamp ?? [Re: Super Scamp] #521755
11/10/09 06:11 PM
11/10/09 06:11 PM
Super Scamp Offline
Super Scamp  Offline
Re: Mini Tub Dart and Scamp ?? [Re: Super Scamp] #521756
11/10/09 06:45 PM
11/10/09 06:45 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Tires are 13 5/8th wide on 10" rim 315/60/15..... 3 3/8 backspacing good inch clearance on both sides... spring boxes inside of framerail. wheelwell lips rolled some .... I may roll the fronts a hair as they havnt been touched and rear in stock location,,,,
Mopar Performance
