Re: Mini Tub Dart and Scamp ??
[Re: moparniac]
#521759
11/10/09 07:25 PM
11/10/09 07:25 PM
Posts: 316 Utah
dragnduster
Utah
Thanks for the pics 540DART, looks like quite a nice car.
Here is 1 more
I like the low tucked look.....
Yea, the motors not to shabby either
[Re: moparniac]
#521760
11/10/09 08:20 PM
11/10/09 08:20 PM
Posts: 2,709 NJ central
Scamp408
NJ central
Tires are 13 5/8th wide on 10" rim 315/60/15..... 3 3/8 backspacing good inch clearance on both sides... spring boxes inside of framerail. wheelwell lips rolled some .... I may roll the fronts a hair as they havnt been touched and rear in stock location,,,,
That 1 of the tires I want to run. If you have an inch clearance on both side I should have no problem moving the tub to the frame rail spot weld edge instead of the frame.
[Re: BEEQUIK]
#521761
11/10/09 09:37 PM
11/10/09 09:37 PM
Posts: 4,085 The Wet Coast, Canada
megajoltman
my 68 dart had 30x13.50 ET Streets on it. It was mini-tubbed but used an aftermarket tub not the factory one.Also the qtrs were stretched 3"
What size tubs did you go with and do you have any pics inside the trunk?
Love that look
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
