Re: Slide Hammer for removing the front pump? [Re: Big Wedge] #521735
11/10/09 07:10 PM
11/10/09 07:10 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I use two 5/16 short studs with a slot cut in one end and thread it down into the case holes through the 2 threaded pump holes. Then use two 3/8 bolts to act like jack screws and pry the pump off evenly. Without the 5/16 studs you may deform the case threads.
Garth
this is how I do mine.
Re: Slide Hammer for removing the front pump? [Re: dartman366] #521736
11/10/09 07:57 PM
11/10/09 07:57 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
I have a pump puller, but rarely use it(on TF's anyway). Grab the stator support with one hand and and tap the edge of the bellhousing with a plastic 3 lb deadblow with the other. Pump pops right off- been doing like that for years.
MB
