Re: Slide Hammer for removing the front pump?
[Re: Hunted Duck]
#521718
11/09/09 08:35 PM
11/09/09 08:35 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I use 2 bolts and a piece of chain,one good pull and it comes right out.
[Re: Chris2581]
#521720
11/09/09 09:55 PM
11/09/09 09:55 PM
Posts: 11,678 W. Kentucky
justinp61
W. Kentucky
I use a bar under the chain to pop the pump out.
[Re: Hunted Duck]
#521722
11/09/09 10:25 PM
11/09/09 10:25 PM
Posts: 16,917 NC
440Jim
NC
Where is the best place to get a slide hammer to remove the front pump. Or is there a different method? Thanks
A slide hammer is a body shop tool and nothing fancy, cheap. You just need a couple bolts (3/8-16 on a 727) coupled to the slide hammer. The other methods do work too.
[Re: TheBlackCar]
#521727
11/10/09 03:57 PM
11/10/09 03:57 PM
Posts: 885 south louisiana
lowell66dart
south louisiana
I like to make tools. Go to the hardware store and get two long 3/8 bolts, like 8 inch if you can find them. Now you need 2 pieces of something heavy with a 3/8 hole thru the center. Round stock like someone suggested works well. Instant slide hammers.
2021 Dodge 2500 4WD Cummins 2020 Challenger R/T Scat Widebody 2007 Charger R/T 5.7
[Re: TheBlackCar]
#521728
11/10/09 04:26 PM
11/10/09 04:26 PM
Go to AutoZone (or local parts house) and buy a cheap dent puller. They are usually less than $10. Take the little threaded tip (that holds screw) off, and the end is male thread and screws right in front pump. There's your slide hammer. Good Luck
This is what I did.
Post deleted by Defbob
[Re: Chris2581]
#521730
11/10/09 05:36 PM
11/10/09 05:36 PM
[Re: VernMotor]
#521734
11/10/09 07:03 PM
11/10/09 07:03 PM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
I just got all thread with a round stock.with a hole drill in it. round stock is 3"x2"
I made the same thing for pulling front pumps... Mine was free, I had all the stuff laying around the garage....
