Re: Build hot street smallblock for $2500?What would you do
[Re: YYZ]
#520448
11/09/09 01:01 PM
11/09/09 01:01 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Start with a 360 that runs well. Upgrade (performance valve job) the heads, replace cam, intake, carb, and headers.
[Re: moper]
#520449
11/09/09 01:12 PM
11/09/09 01:12 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
assuming the core motor has not been bought, I'd pick up a magnum 360 and start there.
assuming it has, I'd go 360, reuse the stock crank, redo the stock rods with ARP bolts, use some KB167's,
for heads, I'd probably go with the RHS/indy magnum heads that hughes sells for ~ $900 assembled. I'd go magnum because you can find nice rockers cheaper (use SBC style rockers). rockers, I'd probably use scorpions, 1.6 ratio
intake, I'd use an eddie RPM air gap.
cam, if you want a hydraulic, I'd go something like a comp XE275HL if you're stuck with a flat tappet. if you start with a magnum, you could use a roller cam reusing the stock magnum roller lifters, and I'd use the comp XR274HR.
[Re: YYZ]
#520450
11/09/09 01:32 PM
11/09/09 01:32 PM
carb,intake,cam,headers,4.10+gears, & 150 shot of NOS. done.
