Re: New MOPAR 5 speed from McLeod!!!!!!!
[Re: LAR_414]
#517302
11/06/09 10:35 AM
11/06/09 10:35 AM
Posts: 1,259 Netherlands
72Challenger
Netherlands
Looks good for the currently more and more big ci / mighty hp streetcars being build. Of course the big Q will be what it will survive on the strip I guess. It's just not me who will figure it out as I just ordered a GForce GF4A trans for the racer. As said, at least it looks tuff!
[Re: StrokerAspen]
#517309
11/06/09 03:31 PM
11/06/09 03:31 PM
Posts: 7,471 Minnesota
Hemi_Joel
Minnesota
I saw it at SEMA, Red from mcleod said they were thrashing to get it done in time for the show. The cluster gear is multi-peice, that allowed them to put a bearing in the middle of it that mounts in a bulkhead thru the middle of the case. That's where the strength comes from. THe overdrive is mounted in the tailshaft housing. It is all syncronized, so I don't know how well it will shift in drag racing applications. I suppose it can be slick shifted just like any 833 trans. I think he mentioned that 2300 price to me also. He also said they came in second place for best new product at SEMA.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: JohnRR]
#517313
11/06/09 06:40 PM
11/06/09 06:40 PM
Posts: 10,550 Rittman Ohio
fourgearsavoy
Rittman Ohio
That shifter set-up looks like it could be the Achilles heel for street use and strips with dust covered pits.Other than that I like the look of it and it looks like you wouldn't need much fabrication to install it in any car. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Jeremiah]
#517315
11/06/09 08:19 PM
11/06/09 08:19 PM
Posts: 9,866 Weddington, N.C.
Streetwize
Weddington, N.C.
Wonder what the gear ratios are??? the Tremec 1 is too deep and the 1-2 is a little wide, I could go for a close to even spread 4 speed with a .8 od. Something like: 2.56 1.92 1.28 1 .8
[Re: CJK440]
#517322
11/07/09 11:24 AM
11/07/09 11:24 AM
fourgearsavoy
Rittman Ohio
That has to be the race version from the look of the straight cut gears and faceplate engagement dogs. Gus
[Re: StrokerAspen]
#517323
11/07/09 11:30 AM
11/07/09 11:30 AM
Posts: 5,997 Salem
Grizzly
Moparts Proctologist
Salem
I LIKE THE LOOK OF THIS AS WELL!
Looks like it means business. So simple. Hope it works as good as it looks.
One of the photos shows straight-cut gears.
And, aluminum case?
Hope the Overdrive ratio is around 0.67
[Re: Grizzly]
#517324
11/07/09 11:47 AM
11/07/09 11:47 AM
Posts: 419 NY
F1Scamp
NY
Man. Too bad I already cut the scamp up for the tko-600. That thing looks bad.
Work In Progress- 71' Duster F.A.S.T.- 10.36@130 Smallblock Record Holder.
[Re: fourgearsavoy]
#517325
11/08/09 01:40 AM
11/08/09 01:40 AM
Posts: 9,092 Rogue River, OR
Jeremiah
Rogue River, OR
What's wrong with dogs on the street? It looks to be the perfect multi-use unit for those of us that like to do some straight line action as well as some corner carving. I'll bet it would live with a street duty slipper clutch....
I'm interested to see how it shifts...I never really liked the feel of the tko's but that's me.
[Re: Jeremiah]
#517326
11/08/09 11:25 PM
11/08/09 11:25 PM
Posts: 869 Sugarloaf, PA. USA
JamiePasson
Sugarloaf, PA. USA
I have known about this for a few weeks already prior to SEMA. The part that really upsets me is that the entire unit is made in Taiwan. That explains the 2300.00 price tag. I have to be honest with you though, I am more than scared looking at the gearset. Hasn't anyone noticed that the gears are VERY narrow. There is little room for load carrying capacity. I understand the bearing support on the cluster gear, However, that will not stop the teeth from wiping off. They say it will take 1000 lb ft of torque. I have heard Keisler state that the TKO will take 1400 lb ft or torque. However, we have seen these units break WELL below the 1000 mark. The thing that everyone is forgetting is... What kind of resistance was put behind the unit. If there is no resistance it should handle 10,000 lb ft of torque. NOW, put it in a 3600 lb car and lets see what happens...
I am not knocking it. I am just stating that physics is physics and we learned A LOT making the OD gearset as to what you need to make things survive. OH, and by the way, to my knowledge, there is no other gearset.
The other point, is... does this really looki like it is gonna fit in an A Body, or a front mount B Body? Just looking, I say no way... Any other input from people?
When I was speaking to Red, he really glossed over the "fitment" issue. He just said that the tail will fit all the Chrysler cars. I think that we all know that there are drastically different dimensions between the the main body styles. We shall see...
I don't know that I would rush out and buy one just yet...
I do welcome discussion on this topic.
Jamie
[Re: JamiePasson]
#517328
11/09/09 07:54 AM
11/09/09 07:54 AM
Posts: 2,463 Answering the call of the wild
ThermoQuad
I am very skeptical the depicted box in the linky will fit in the tunnel of an E body or a 68-70 B body. Being a bit older, maybe wiser now I will await the reports from the people who jump in and get rather than get myself Good luck... In the meantime I will continue the yearly torture testing of the Passon Aluminum 4sp OD in my pos on the road course and the drag strip.
[Re: wicked]
#517329
11/09/09 09:56 AM
11/09/09 09:56 AM
JamiePasson
Sugarloaf, PA. USA
Wicked, Its funny you say that. That is exactly what it is. I am just very skeptical as to fitment. Like I said, when I spoke to Red at McLeod, he didn't even know what I was talking about as to the different crossmember locations and shifter locations. Lets look at the details, What about shifter handles, More $$$ can you use a console? trans mounts and crossmembers, More $$$ speedo cables, etc, more $$$ driveshaft length, more $$$
So, once again, the $2300 really isn't $2300 at all...
Just pointing out details that surface once you start to try to put it in the car.
[Re: JamiePasson]
#517330
11/09/09 10:30 AM
11/09/09 10:30 AM
Posts: 227 Tennessee
rj8806
Tennessee
.... I have heard Keisler state that the TKO will take 1400 lb ft or torque.....
Actually Jamie, it is not Keisler that says the TKO will take 1400 ft/lbs, it was Tremec. ....and what our Tremec rep said was "they had a TKO-600 on a dyno and hit it with 1400 ft/lbs and the jig holding the tranny broke".
Take that for what it's worth as none of us here at Keisler were there when then went down, but we have never told anyone that a TKO-600 will definitely stand up to that much torque.
Richard Tech Support
[Re: JamiePasson]
#517331
11/09/09 12:05 PM
11/09/09 12:05 PM
Posts: 904 cleveland Ohio
mloboda
cleveland Ohio
.... The part that really upsets me is that the entire unit is made in Taiwan. That explains the 2300.00 price tag...Jamie
That's right, everybody just keep on buying chinese made junk 'cause it's cheap. Mcleod will never get another dime of my money. To me, that's GREED. Plain and simple. The next job lost is increasingly more likely to be your own.
[Re: JamiePasson]
#517335
11/09/09 03:29 PM
11/09/09 03:29 PM
rj8806
Tennessee
No worries. I didn't take your response as a dig to us, I just wanted to make sure no one reading this took it the wrong way. If they go back and look at my past posts, I have had nothing but good things to say about you and your transmissions and I have always seen your opinions to be very informative and upbeat. Richard Tech Support
[Re: LAR_414]
#517336
11/09/09 03:34 PM
11/09/09 03:34 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Other than custom stuff like Viper 6 Speeds, Richmond 5 speeds, etc. Right now we basically have 3 choices for a steetable OD manual trans: Passon, Kiesler, and Gear Vendor.
All of them have thier good and bad points, the reasons people choose one over the other often comes down to nothing more than personal choice. I wouldn't mind seeing another choice come into the market, it will likely have it's good and bad points as well but the price, even though bare bones, makes it look pretty good. Time will tell.
[Re: hemicop]
#517338
11/09/09 04:59 PM
11/09/09 04:59 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
I must have walked right by this thing. No mention of it being a Mopar app that I saw. Sure looks like it sticks out in spots where the floor is. The shifter deal looks a bit funky, but boots should prevent and dirt issues. Not happy with the import deal, but to the guy that said we buy because it's cheap, maybe it's more like buy that or nothing.... I sure won't be in the market for one in the near future, but I'm glad there is another choice. T oo many booths said that they do stuff, untill they saw my Mopar badge and shirt. I even had one guy say "Why don't you just go with an LS1 like everyone else?" I expect he drives a silver econobox and lives in a planned gated community...
[Re: hemicop]
#517339
11/09/09 05:00 PM
11/09/09 05:00 PM
JamiePasson
Sugarloaf, PA. USA
I see your point. I am not trying to be a jerk. I am not pointing out the shortcomings. I am pointing out that it doesn't seem like it is gonna be able to fit where they say it is going to. Has anyone looked at how far above the trans the shifter mechanism is? There is NO WAY that is gonna fit without cutting the floor. I doubt that a console will fit over it either. Well, I don't want to get a bad rap here. So, I will just wait and see what develops with it... Jamie
[Re: hemicop]
#517340
11/09/09 05:36 PM
11/09/09 05:36 PM
Posts: 74,911 U.S.S.A.
JohnRR
U.S.S.A.
I saw the piece at SEMA and was told fitment in an A-body was no problem, so why would it be an issue in a B-body? Again, at SEMA, I was told there'd be 2 mounting points to accomodate people so again what's the problem? Most hotrodders nowadays have custom driveshafts built so AGAIN I don't see an issue. Now it being Chinese made I understand & agree with being concerned. As a consumer & someone not in the automotive industry I find it "intersting" that representatives from other companies are so quick to highlight its shortcomings when there hasn't even been published performance results on the thing. That's kinda like finding someone guilty before a trial......
70 and earlier B bodies have their shifter mounting point FOWARD of a A body and VERY forward of an E body , I own both an A body and a 69 B body , no way that thing is going in there with that tailshaft without HACKING the tunnel , as it is I think the cover on the trans is going to require some MASSAGING of the tunnel to fit .
[Re: CJK440]
#517342
11/09/09 06:56 PM
11/09/09 06:56 PM
JohnRR
U.S.S.A.
Interesting gear arrangement and it looks pro-shifted. Perhaps they offer different gear sets with traditional syncros?
I hope they offer a HELICAL gearset , that straight cut gear will not be fun in a street car
[Re: JohnRR]
#517343
11/09/09 07:45 PM
11/09/09 07:45 PM
Posts: 383 Essex, Ont., Canada
Fishmarket
Essex, Ont., Canada
I believe the link stated that the trans was available with different tailshafts for Mopar, Gm and Ford apps. Who says that the one shown is for a '69 B body?
1972 Plymouth Cuda 340 4 speed
1971 Plymouth Road Runner 383 Auto
1970 Plymouth Duster /6 Auto
[Re: B1KILLER]
#517345
11/09/09 10:31 PM
11/09/09 10:31 PM
Posts: 3,412 Toronto
mshred
Toronto
Everything that shines, ain't gold. I wont be the guinea pig, I will wait for proof. I'll stick to my Glide till then. Saving my pennies for a liberty or jerico.
agreed...i got a little excited when i saw this tranny since it is another 5 speed option for everyone, but the price seemed too good to be true, and now after reading it is taiwan produced it is obvious why...mind you, as much as i support North American made products, not ALL overseas stuff is bad...i read that gm version will be out in march 2010 with mopar ones soon to follow...way i see it is let the chevy boys be the guinea pigs for us mopar guys lol
[Re: mshred]
#517346
11/09/09 10:48 PM
11/09/09 10:48 PM
Jeremiah
Rogue River, OR
Oh man...what a drag. I did not realize this unit was made outside of the US...my goal in saving for a OD trans was to get one made in-country.... I guess I will have to do some soul searching on this one. Perhaps the obvious choice would be sticking to a reliable vendor that has helped me mucho in the past <cough> Passon... Interesting read, keep it coming folks.
[Re: Fishmarket]
#517348
11/10/09 10:40 AM
11/10/09 10:40 AM
JohnRR
U.S.S.A.
take a close look at the tailshaft , if I remember right someone said 5th is in the tail , like a T 5 is ... i vaguely remember when I pro shifted one ... with this in mind look where the trans mount is , for a 70 down b body the shifter and it's INTERNAL RAIL system will have to be FORWARD of the mount , ASSuMEing the mount is in the stock mopar location .
We have another drop in NO HACK 5speed on the market and anyone with half a brain and an internet connection have read the horror stories of their installations , i have a friend that putthe TKO in his 69 RR , he didn't heed my warning and had the car painted , put the motor in and some the incorrect engine trans angle , had to hack open the floor pan to get the angle closer , but not factory correct ... I believe the link stated that the trans was available with different tailshafts for Mopar, Gm and Ford apps. Who says that the one shown is for a '69 B body?
[Re: B1KILLER]
#517349
11/10/09 10:43 AM
11/10/09 10:43 AM
JohnRR
U.S.S.A.
exactly , I'll wait till someone actually installs one in a mopar A or B body before I plunk down the cash ... but then again a faceplated straight cut gear trans isn't what I would consider street friendly ...
[Re: theclutcher]
#517351
11/10/09 11:17 AM
11/10/09 11:17 AM
Posts: 16,122 Grand Haven, MI
patrick
Grand Haven, MI
FWIW, I believe most Tremec trannies are made in Mexico now... just sayin'.....
[Re: theclutcher]
#517353
11/10/09 01:02 PM
11/10/09 01:02 PM
JamiePasson
Sugarloaf, PA. USA
Well, I was not going to say anything just yet, BUT I feel that in light of the recent buzz about the McLeod trans, I guess it won’t hurt.
For a couple years now, we have been working on a NEW 5 Speed trans for Chrysler cars. We were not aware that McLeod was also doing it.
This is a clean sheet project. In other words, we are building this from the ground up. Due to our extensive experience with the cars that it must fit into, our individual designs that we will be offering will make installation easy. In fact, we feel that it will be something that the average guy can put in their car in just a few hours.
This unit will be a BOLT IN!!!!!!! No monkey business with driveline angles, notching torsion bar crossmembers, redrilling bellhouisngs, changing clutches. You will retain your ORIGINAL shifter handle in the ORIGINAL location. The unit will look like it came from the factory in the car. It will be a HURST style shifter arrangement with external linkage, just like the design of shifter that these great cars left the factory with.
There will be an A Body trans There will be a B Body trans (‘63- ‘69) There will be a'70 - UP B/E Body trans.
You will use your ORIGINAL driveshaft and yoke You will use your ORIGINAL transmission crossmember and trans mount You will use your ORIGINAL bellhousing You will use your ORIGINAL flywheel, You will use your ORIGINAL clutch and throwout bearing (18 spline only)
The unit WILL fit under the floor pan with no modifications.
Due to the simplicity here, it WILL be as easy as changing the trans. Truly an afternoon job.
As for cost… I can tell you this, it will not be $2300.00, HOWEVER, I feel that the price will be fair considering that the unit is MADE for the car. Versus taking an existing trans and trying to shoehorn it in and not cut the car as other manufacturers have tried in the past.
To accomplish the project, we have drawn on the years of gear cutting experience from our partner GFI. This is the organization that we have been working with our very successful Hemi OD project. They have a brand new CNC gear cutting facility that WE will be manufacturing the units.in.
And now for the BEST part…….
IT IS MANUFACTURED IN THE USA!
There will be more to come….
[Re: JamiePasson]
#517357
11/10/09 03:02 PM
11/10/09 03:02 PM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
How much power will it handle? Will it be a street only unit, or should it be also strong enough for racing on slicks?
[Re: JamiePasson]
#517359
11/10/09 03:40 PM
11/10/09 03:40 PM
Posts: 554 Florida
65HemiCoronet
Jamie, I had been researching the parts needed to do a 5 speed in my 65 Coronet recently. I've got a 528 hemi 750 hp, 725# tq. I was just about to pull the trigger on beginning to buy parts when I saw the bit about the McLeod unit. I got pretty excitied about it until I read more of this thread. I take it it would be worth my while to wait a bit more and get more info on your new trans. Any rough idea of when they might be available? Thanks.
Yeah, it's got a hemi........a REAL hemi.
[Re: mshred]
#517361
11/10/09 07:00 PM
11/10/09 07:00 PM
Posts: 3,354 ohio
HEMIDARTS
ohio
Jamie i have been sitting here thinking to myself, This sounds like something that Jamie should be doing. I am glad you have made a 5 speed. I know your tranny's are the best out there! I hope everyone will atleast do the research when you want to buy a tranny, and you will find out how great Jamie is and his product is that much better!!!
[Re: JamiePasson]
#517362
11/10/09 07:02 PM
11/10/09 07:02 PM
Posts: 12,008 Finally a HUSKER again
Moparnut426
Jamie,,,,
Im sure it will sell like hot dogs in a ball park...
The true drop in is what 90% of us gear heads want. I converted my Demon to a rowing maching, and I really want a 5 speed, but dont want to cut anything up again, it was a big enough pain in the ass to find a good 4 speed hump, and I dont want to deal with the mess again. THis was before I could get a new floor...
Kasey
[Re: JamiePasson]
#517364
11/10/09 08:15 PM
11/10/09 08:15 PM
Posts: 1,496 Sask, Can.
72demon416
Sask, Can.
That is really good news Jamie! it's great that your throwing this option out there for those of us who refuse to cut out cars up and still have the best of all worlds. I can't wait to see the finished product! Rick
[Re: JamiePasson]
#517365
11/10/09 08:30 PM
11/10/09 08:30 PM
fourgearsavoy
Rittman Ohio
Does anyone want to buy a Richmond 5-speed??? I still have all my factory stuff to make an 833 work in my car Gus
[Re: fourgearsavoy]
#517366
11/10/09 08:33 PM
11/10/09 08:33 PM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Jamie,,,,
The true drop in is what 90% of us gear heads want. I converted my Demon to a rowing maching, and I really want a 5 speed, but dont want to cut anything up again Kasey
DITTO!
[Re: 72demon416]
#517367
11/10/09 08:34 PM
11/10/09 08:34 PM
Hemi_Joel
Minnesota
I think it is great that Mcleod is building this, even tho unfortunataly it is apparently foriegn built. We are fotunate to have companies like McLeod and Passon and Liberty and G-force and the others who are willing to step up and make cool stuff for our old Mopars! I don't like buying foreign, but it sure seems to be a way of life nowdays. For cripes sake, my 93 dodge dually was built in Mexico, my 04 Dodge Ram was built by a foriegn company, THe crank and rods in my Hemi are forign. I wish everything was USA built like in the old days, but what's a guy to do? You have to go with what is best going to accomplish your goals, all things considered. When Passon came out with his 4 speed overdrive gears, I thought it was the greatest! Looks like Mcleads 5 speed is a cool deal too, and I'm sure Jamies 5 speed will be excellent. When I get my but in gear and get my green GTX back on the street, I'm still thinking I'll go with the Passion 4 speed overdrive. With big inch Hemi tork, you don't really have a use for 5 gears any way.
[Re: JamiePasson]
#517369
11/11/09 06:40 AM
11/11/09 06:40 AM
Posts: 554 Florida
65HemiCoronet
I think my choices would be gear option #3 for those who want "maximum overdrive" (that was a movie wasn't it?), and options #1&2 are fairly close, maybe something in between those two for the second one? Again any idea when we may see something on the market?? (not to rush you or anything!)
[Re: JamiePasson]
#517370
11/11/09 09:27 AM
11/11/09 09:27 AM
JohnRR
U.S.S.A.
We are SWAMPED today. I will hopefully get back on here later with some more info. I am a little reserved as to saying too much just yet. It will be more than capable of handling almost anything that you can throw at it. (We are not finished testing just yet, so I am not spitting out any figures) As for a street only, we are planning to make a full race version as well, but this will be down the road. You will certainly be able to race the standard version.
Jamie , you've already said to much , I wouldn't say another word till you are ready to go to market .
Just remember what happened when everyones favorite provider of CCJ spoke to soon and also was dumb enough to quote an UNREALISTIC price , you're smarter than that i see, then couldn't come to market because his price wasn't realistic and the market wasn't there...
[Re: 65HemiCoronet]
#517372
11/11/09 09:32 AM
11/11/09 09:32 AM
patrick
Grand Haven, MI
my are this: I personally like the richmond approach, of having a deep first and direct/low OD 5th. this would allow the use of a tall rear gear, which case for case is stronger than a steep gear, and it has the big benefit of keeping driveshaft RPM down.... What would be neat would be to have 2 gearsets, one with a 3.30-3.50ish first gear and a 1:1 5th, or so. maybe something like a 3.3/2.2/1.5/1/.8 or .85 if 5th needs to be OD, or a 3.5 first, and your proposed 1-4 ratios as 2-5. for those with dana's, who their tallest gear choice is a 3.54, option #3 looks like the best bet.
[Re: RTSE4ME]
#517377
11/11/09 10:51 AM
11/11/09 10:51 AM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
This should be great! And as far as pricing if I buy a part and it fits and works like it should I'm happy. A $3500 part that I have to spend months working out the bugs on is not half as good (to me) as say a $4500 part that works right out of the box.
A new iron curtain drawn across the 49th parallel
[Re: patrick]
#517378
11/11/09 11:01 AM
11/11/09 11:01 AM
Posts: 554 Florida
65HemiCoronet
my are this:
I think, and this is just my opinion, that offering a 1:1 fifth gear is not the way to go considering an aftermarket item that would be used in conjunction with what is installed in most performance cars.....meaning that I think for the most part, guys are currently running 3:70, 4:10 or a bit higer rear gears and are looking for a 5th gear to bring the cruising rpms down. By offering a lower first gear and a 1:1 5th, they would have to change the gears in the rear to take advantage of it. More costs to buying the trans to put in an existing car... Again just my opinion.
[Re: JamiePasson]
#517379
11/11/09 11:15 AM
11/11/09 11:15 AM
Posts: 2,172 Ohio
theclutcher
Ohio
Great news, . Maybe a ratio like the red stripe with od for 5th, probably would be popular. Maybe do some homework and design ratios for a race only set with 1-1 fifth. Again, hats off to you.
[Re: JamiePasson]
#517381
11/11/09 03:00 PM
11/11/09 03:00 PM
Posts: 320 Clinton Twp. MI.
ChargerDude70
super street
super street
Clinton Twp. MI.
"We are possibly considering a different 1st gear ratio as well, but it is likely that we necessitate changing 2nd and 3rd as well to accomodate. I am not sure about that yet." A "gear-set" that was set up for drag racing(ish) and having that OD for the cruise home would be nice. I personally have a 3rd gen hemi in my car and Chyrsler put 3.59 first gear in the NAG trans to help the car out of the hole then has a .67 for 5th. Allows us to put 3:23 or 3:55 in rear and have best of both worlds. Just my
DODGE...Devistation On Driving Grounds Everywhere
69 Dart Swinger 6.1 Hemi 4-Spd
70 Charger R/T B3/B5 6.1 Hemi Auto
76 Coronet
2008 H.D. Street Glide Aniversary Model 821 of 3000
2011 Challenger R/T T.O. 6spd
[Re: ChargerDude70]
#517382
11/11/09 08:05 PM
11/11/09 08:05 PM
fourgearsavoy
Rittman Ohio
Jamie have you contacted Long for a shifter yet or can we use the current 5-speed Hurst unit on the market now? I also like the 1.1 fifth concept like my Richmond with a 3.27 low gear.The 3.54 rear gear with that low gear works pretty well for my 3500# car with the 493 The #2 choice with a 4.10 gear would work well also You need to have a good mechanical advantage to keep the clutch from glazing on the launch. Gus
[Re: fourgearsavoy]
#517383
11/11/09 10:15 PM
11/11/09 10:15 PM
JamiePasson
Sugarloaf, PA. USA
Gus, In keeping with the true bolt in deal. In other words being open and up front as far as costs go, the transmission will include a shifter and linkage. If we didn't do that, we wouldn't be any better than the "other" guys out there because you would need another $400+ dollars worth of shifter and linkage to be able to use the trans. It will be a HURST style shifter. Long makes good stuff, but it just isn't gonna fit where it needs to. A note to everyone. Making a .85 OD ratio in my opinion is a waste of time. Our current OD Hemi 4 speed gearset has a .80 and I have heard people saying that it isn't enough overdrive. So, I can tell you that is out. I am on the fence about making a 3.2 first gear. That is PRETTY steep. If we make a steeper 1st gear, I am thinking something in the 2.9's. As for Quadrini, I'll never tell. Thanks, Jamie
[Re: JamiePasson]
#517384
11/11/09 11:43 PM
11/11/09 11:43 PM
patrick
Grand Haven, MI
the .8 of the 4 speed isn't steep enough only because first isn't steep enough
check out the A580 tranny ratios in the LX's....mid 3.59 for first, and IIRC, a .83 OD, coupled with a 2.82 rear, has the same gear multiplication as a 2.64 first and 3.83 rear, and the final drive of a 3.54 with a .66 OD.....to me, the big thing is this strategy keeps the driveshaft RPM down. for instance, for a 27" tall tire at 120 MPH, that's 1495 RPM at the wheel. using a 4.10 gear and .66 OD make the driveshaft RPM 6130 RPM, with the engine at 4050 RPM. a deep first/1:1 OD with a 2.71 rear has both the driveshaft and engine spinning 4050 RPM at the same speed....
the crown victoria police interceptors are actually electronically limited to 125 MPH because of driveshaft RPM....
[Re: JohnRR]
#517385
11/12/09 06:34 AM
11/12/09 06:34 AM
ThermoQuad
With that release date i'm assuming Tom Quad has already tested one in his killer AAR ???
I am waiting for the call to show up with my car for the transplant...yes the product will be torture tested...I can't wait... Road racing just got better.
Thanks Jamie!
[Re: 67autocross]
#517390
12/25/09 03:56 PM
12/25/09 03:56 PM
Posts: 2,402 Wichita,KS
Blakcharger440
Wichita,KS
And for me a $4500 trans would be out of the question as would be the same for alot of realistic budget based Mopar hotrodders.
Kudos to Passon for stepping up to the plate in developing a drop in trans for the Mopar community and the cherry on top would be that it is made in the USA but....if the pricing isnt there then for most it will not be a option.
This is only my opinion and I consider myself your average mopar hobbyist.
[Re: MadMatt]
#517392
12/26/09 12:51 PM
12/26/09 12:51 PM
fourgearsavoy
Rittman Ohio
The BEST part of Jamie's trans is that you don't need any special custom parts to install it Everything you need can be had from the Moparts community in good used form such as bell,flywheel,fork,Z-bar etc... The keisler unit needs some custom parts that only they manufacture.When you do that then you have a baztard-Frankenstein unit that they only supply parts for. Gus
[Re: ScottSmith_Harms]
#517395
01/10/10 08:37 PM
01/10/10 08:37 PM
Posts: 5,067 Orlando Florida
blown572dart
Orlando Florida
If Jamie builds a true bolt in kit for A-bodies, and the price for a conversion is comparable to the Keisler I will buy one.
X2
X3
[Re: Blakcharger440]
#517397
01/10/10 10:08 PM
01/10/10 10:08 PM
mshred
Toronto
x2
[Re: mshred]
#517398
02/22/10 01:10 AM
02/22/10 01:10 AM
Posts: 1,757 levittown pa
fstfish66
levittown pa
ill be watching this topic,,
im in need of a 5 speed box with a steep 1st gear and a nice OD,, i run a 33 inch trall tire,,,and drive to a lot of cruise nite,,, i justy removed a 4;56 and put in a 3;91..
with the correct gear selection,,and a 5 speed i could have just as good off the line performance and cruiseablitly,,,a stock 1st gear wont work in my application,,
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
[Re: JamiePasson]
#517399
02/22/10 01:20 AM
02/22/10 01:20 AM
Posts: 2,432 NorCal
RylisPro
NorCal
I have three gear ratio options. The difference is the 5th gear ratio.
Any hope for a 6 speed?
thanks
[Re: RylisPro]
#517400
02/22/10 03:13 AM
02/22/10 03:13 AM
Posts: 254 Vista, CA
71Chip
Vista, CA
I guess this really hasn't been done/talked about enough, but if you are going to cut the floor up anyway for the Keisler unit... Tremec T-56 6 speeds out of GM f body cars can be had on E-bay for 600 bucks. Quicktime makes the bellhousing to bolt this trans to small or big block mopars.
Doesn't take much reading on ls1tech.com or other GM/Viper/Cobra sites to see the t-56 has been proven FAR past its given torque rating.
As far as 5 speeds, there is a lot more market for a $5k bolt-in trans than a $5k cut-it-up trans.
71 Challenger
[Re: 71Chip]
#517401
02/23/10 06:38 AM
02/23/10 06:38 AM
Posts: 4,862 the frozen wastes...
Pale_Roader
Swears too much
Swears too much
Based on what i see now, and this is the number one hangup with my Challenger project right now (needing an OD stick), this is probably what route i'd take.
The McLeod unit is still up in the air by the sounds ov things. But the price is at least decent. And really, i could give a [Edited by Moparts - Family Friendly Site - Keep it clean] where it was made as long as the quality is there. China doesn't necessarily mean junk, just like homebuilt doesn't necessarily mean quality.
Keisler sounds decent for what i need, but i'm not rich, and i still hear the Tremec has high-speed shifting issues. I wish they made a T56 kit... then again, that'd be even more coin now wouldn't it...???
Richmond or other custom stuff is more expensive than Keisler, and probably (even more ov) a nightmare if something breaks in the middle ov nowhere.
The Passon 5spd again, outta my budget, no matter how good it is. And personally, not a fan ov the 4spd OD idea, drove one (a stock truck unit in a 340 Demon), and just did NOT like the gear spread. I wouldn't even want that in a 440 car where the torque could mitigate the disadvantage.
The stock 1:1 4spd and 2.76 rear gears has an obvious disadvantage. This is my default route, hopefully i can find a better way by crunch time.
I really like the T-56 though. I'm sure someone out there has come up with a cheaper way to use it behind a Mopar big block by now. I really like the idea ov having a 4.56 or lower gear, and still running like a 2.76 on the highway. Even with a 5spd OD i'd still be stuck with a 3.91/4.10 ish rear gear to keep a really long final gear on the highway.
Anyone else done this 'junkyard' T-56 swap (since we're already derailing this thread a bit...)
[Re: Pale_Roader]
#517402
02/24/10 11:38 AM
02/24/10 11:38 AM
JamiePasson
Sugarloaf, PA. USA
See, this is where you are wrong. Our 4 spd OD gearset isn't even close to the gearset in the truck trans that you drove in the Demon. I don't feel that you are giving that option a fair shake.
As for the imported thing, that is entirely your call. The unit is actually made in Korea, not China. If it doesn't matter to you that it is imported, that is fine, it sounds like it should fit what you need and it will fit into your budget. What kind of horsepower did you have? Thanks, Jamie
We are looking at less then 5 grand for this unit.
*fixed your quote for you Jamie
[Re: mshred]
#517406
02/24/10 04:56 PM
02/24/10 04:56 PM
patrick
Grand Haven, MI
t-56 feedback:
the LT1 trannies have an oddball midplate and clutch arrangement (IIRC it's a pull type vs. push type pressure plate) that may be difficult to adapt to mopars
and the F body trannies have a weak 27 spline output shaft. I have a friend with a '96 impala with a 396 CID LT1 stroker and T-56 who snapped the output shaft the first time he took it to the drag strip (with street tires). he upgraded it to a viper tailshaft (uses the same spline as a 727). eventually he picked up a chev SSR T-56 to eliminate the funky LT1 clutch, and for better overall gear ratio spread. IIRC, it uses a larger output shaft, similar to the viper's.
[Re: mshred]
#517407
02/24/10 09:08 PM
02/24/10 09:08 PM
Blakcharger440
Wichita,KS
for 5K you can buy a liberty or g-force five speed and never have to worry about breaking a trans again.
What is your choice in O.D. gear in one of those?
[Re: mshred]
#517409
02/25/10 10:17 AM
02/25/10 10:17 AM
Blakcharger440
Wichita,KS
sorry man, but if im gonna pay 5k for a tranny id be alot more concerned with its strength then just for the fact that it has OD...mine as well just buy a gear vendors
I hear ya. I think that alot of people are looking for one trans to try and pull double duty as a race trans and be livable on the street/highway without maxing out the RPM.
But I agree that strength would be the main concern.
[Re: theclutcher]
#517412
02/25/10 08:17 PM
02/25/10 08:17 PM
mshred
Toronto
Possible any currently made straight cut gears fit into existing 833 with little mods? how many red stripe sets you sitting on, any 9310 clusters etc?
id be interested in this as well
#517415
03/14/10 05:33 PM
03/14/10 05:33 PM
fourgearsavoy
Rittman Ohio
I don't have 100% confirmation on this but I think he may be doing conversions in his new expanded shop.As far as a conversion goes all you would need is everything in front of the tranny like the clutch ,flywheel,can,and pedals.Your crossmember and driveshaft would be the same and the tranny will come with the shifter as I understand. Gus
[Re: 73chally]
#517417
03/16/10 10:52 PM
03/16/10 10:52 PM
fstfish66
levittown pa
you can buy most if not all stock factory repopped linkage and hump from brewers,,,but if you have big tube or custom headers ,you may consider going hyd clutch of some sort,,either a hyd bearing or slave cylinder,,i built my own system,works great
[Re: MadMatt]
#517419
03/17/10 11:43 PM
03/17/10 11:43 PM
fstfish66
levittown pa
ok,,1st of all..this site isnt pic friendly to older digital cameras,,if pics are bigger then 3 megapixels they dont post,,,i now have a camera with adjustable picture size,,but those ;ics are too big to post and there are a lot of them,,,ide gladly E MAIL you a few so you can get an idea of what i used,,,heres a little bit about what ive used and what i currently use,, for about 10 years, i used a tilton hyd bearing,hard mounted in to the scatter shield, it didnt have enough travel to work properly,,as i learned,and it was a nascar bearing built for the GM stuff,,but had parts that were suppost to make it fit a mopar application,,as time went on,1st gear got harder and harder to get in to at stop,,,then it wasnt engauging enough and wore out the 4th gear syncro,,at the time i installed this unit,,between tilton and center force, i didnt get correct specs form either of the 2 companies,,so when it failed i investagated it again,,learing what i believed to be the correct specs,,and not enough travel of the bearing,,i could of shimmed it but it may not of wanted to return or relax enough to not wear the pressure plate fingers,,and by this time i didnt want to have to pull a tranny in a early A body again to service it,,so i went with a slave cylinder,,puller type from speed way motors,,i think the travel on the slave cylinder is 1 1/8, and i used a wilwood master designed for a hyd clutch,,it had the longest stroke and a 3/4 bore,,the master has to be installed 2 inches below the pedal pivot point to have corect travel,,on my A body, that is where the speedo cable went thru,,so i moved the cable and made that hole big enoiugh for the master,,,also made a plate inside to support the thin sheet metal of the fire wall,,a heim joint on the end of the push rod,and a bracket i made and welded it to the clutch pedal,to space it out to reach left of the pedal to the push rod,,,the slave cyl is currently mounted in the factory hole of the fork,,but i am going to dril a hole 1 inch in,to creat more fork travel,,and less pedal travel,,but my pedal have a lot of play,i will address that before moving the slave attaching point,,,i can supply a ton of pics if you e mail me your e mail if your intrested,,,slave cyl 45 bucks,,master 49 bucks i believe,, fstfish66@aol.com
[Re: fstfish66]
#517420
03/18/10 06:13 PM
03/18/10 06:13 PM
Posts: 1,212 QLD Australia
Keith Black®
QLD Australia
these guys supply a hydraulic clutch master cylinder & linkage kit. I've just ordered one (it's impossible to order from Keisler or those that offer "complete kits" - my experience was unless you're ordering the whole system you are priority No. 62,342). http://www.hotrodhydraulics.com/Mopar-Product.htm#HYDRAMAX™ Master Cylinder Kit
-------------------------------- Darren Beale Keith Black Racing Engines®
[Re: Keith Black®]
#517421
03/18/10 08:41 PM
03/18/10 08:41 PM
Posts: 301 wisconsin
swifter
wisconsin
Listen up men::After recently having to pull my ol'833 three times because of seal failing in my brand new hydrolic t.o. bearing from this new 5 speed supplier I would really think twice about rushing out because of a price tag!!!! welcome to the world of human guinni pigs--Any wait on Jamie's 5 speed is well worth it--All you have to do is meet Jaime in person (as i did last year at nats) and you find out he is a genuine trany guru and will stand behind any product he sells--His knowledge is spot on and I'm sure he would not put his name on anything unless it was top notch.Cost more yes of coarse it will, but in this day someone who is investing his time and money to release a AMERICAN MADE ITEM should be applauded for his efforts.GO JAMIE GO --Steve
2007 Ram 2500 Cummins
2008 Dodge Nitro
1970 340 Valiant Duster
[Re: Keith Black®]
#517422
03/19/10 01:06 AM
03/19/10 01:06 AM
fstfish66
levittown pa
yikes,, so sad,,but so true,,,was funny reading,,
[Re: Keith Black®]
#517424
03/19/10 08:27 AM
03/19/10 08:27 AM
Posts: 211 Tennessee
Keisler Sales
Tennessee
We have no problem selling the master assembly I don't offer a A833 throw out bearing.
Keisler Engineering www.keislerauto.com#1 Choice of Overdrive Transmissions with Over 14,000 Sold
[Re: JamiePasson]
#517425
03/22/10 06:25 AM
03/22/10 06:25 AM
Pale_Roader
Swears too much
Swears too much
Whoa, maybe i should check back more than once a month here... heh heh...
My bad, i didn't know the one you offer wasn't a superwide spread like the truck unit. Thing is, i liked that 1st gear, especially since both my temp engine for this project and the final engine will be high-RPM, lower torque engines (thinking 383-426 N/A lowdecks, both). I liked the steep 1st, i just didn't like the spread. The owner didn't seem to mind, nor did the guy who installed it, but that would bug the hell outta me... like shifting from 1st to 3rd in a race... ugh.
Your 4speed has a nicer spread, but its still a bit wide for my taste. Its great that others like it, its just not for me. I like that 1:1 4th. I really just want 5-6 gears in my box. Maybe if i could actually drive one i might like it? i could be that far off base...???
Even the 5-speed would get old for me i think. The engine i build will want at least a 4.56 gear, but i want a 2.76 for the road. I know... i really dont want much... haha. Really, i want a 6-speed. I'd go with a 5, but after spending all the money it will take go buy any one ov these kits, i'll still be thinking ov that 6th gear, the one that turns my 4.56's (or more) into a real highway gear.
Really, it just kinda bugs me that with all these cheap (say, Cobra-spec... which are plenty strong) T-56's out there i still cant easily bolt one up to my big block.
Oh, and not sure which engine you are asking about, but the 'temp' one going in my car will be around 400-450HP, maybe a bit more depending on if i can find some cheap aluminum to cover the bores. That 340 in the Demon was pretty hot, probably a bit under 400?
[Re: JamiePasson]
#517426
03/22/10 09:56 AM
03/22/10 09:56 AM
Posts: 8,165 Left Coast
BobR
Left Coast
I may be one of the first in line for your E body version. Since I put 4.10 gears in my T/A I no longer enjoy driving it around town. However, I don't want to give up the additional torque multiplication and I don't want to cut my car up. I would like to see a .75 overdrive and a 2.90 first gear. This would be perfect for me.
[Re: Pale_Roader]
#517427
03/22/10 10:00 PM
03/22/10 10:00 PM
fstfish66
levittown pa
wondering if the MC,Leod unit or people will be at chryslers at carlisle,, to show or talk about the tranny,,,,ide like to see it up close,,,
[Re: fstfish66]
#517428
03/22/10 10:34 PM
03/22/10 10:34 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
me too....
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
[Re: Old School]
#517429
03/22/10 11:42 PM
03/22/10 11:42 PM
fstfish66
levittown pa
me too....
ANY ONE HAVE A CONTACT NUMBER??? from what i have read here MC,LEOD is not part of B&M any longer??? how do we get a hold of red roberts??? ill call and see whats the scoop...
