904 and 727. Do they go together the same way? #515829
11/04/09 11:36 AM
11/04/09 11:36 AM
Newark, OH
Hunted Duck Offline OP
Newark, OH
I am looking at doing my own trannies. I am looking at Carl Munroe's book for 727's. Is this book going to be able to help me with a 904? Still not 100% sure I am going to do my own trannies. But I would atleast like to get a feel for it. I am probably going to go to CRT's class if time allows.
Re: 904 and 727. Do they go together the same way? [Re: Hunted Duck] #515830
11/04/09 12:03 PM
11/04/09 12:03 PM
Indiana
YbNoRmAL Offline
mopar addict
YbNoRmAL  Offline
mopar addict
Indiana
They assemble the same way...if you can do one you can do the other. Pretty much the same transmissions...just one is bigger than the other or is it one is smaller than the other. CRT
Re: 904 and 727. Do they go together the same way? [Re: Hunted Duck] #515831
11/04/09 12:06 PM
11/04/09 12:06 PM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
Pretty much the same.
904 over-running clutch cam (stock) is riveted into the case, where the 727 is pressed in and held by a socket head set screw.
904 low/rev band linkage is a little different. The 727 uses a bracket that's held on a pin thru the rear of the case. The 904 has a slightly different set-up.
904 front planetary and annulus gear are held together (2.74 1st) with a snap ring, 727s just slide together.
904 front pump has two complete halves, 727 has the main pump housing with the reaction shaft support bolted on the back side. You have to make sure the 904 pump halves are aligned. I use a large worm screw clamp, or you can install the pump backwards into the trans case and tighten (torque) the pump half bolts.
904 uses one large (stock) direct clutch piston return spring, 727 uses a multiple peg piston that uses 6-15 springs.
904 forward clutch housing and splined hub are one piece, 727 forward clutch housing and splined hub and held together with a snap ring.
If you have the Carl Munroe 727 book, you should'nt have any problems with the 904.
John
Re: 904 and 727. Do they go together the same way? [Re: DusterW2] #515832
11/04/09 12:49 PM
11/04/09 12:49 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tony
70 AARCuda Vitamin C
Re: 904 and 727. Do they go together the same way? [Re: 70AARcuda] #515833
11/04/09 02:03 PM
11/04/09 02:03 PM
Newark, OH
Newark, OH
Thanks for the info guys. I am currently running a 727 but am thinking of going back to a 904.
