Ladder Bar Question #513887
11/02/09 12:37 AM
11/02/09 12:37 AM
Las Vegas NV
moparmanjames Offline OP
Las Vegas NV
Hey guys, I'm having a full fram put in at a shop and I had a ladder bar angle concern. I bought the back half out of a car that was in the shop and I don't think the brackets are correct for how low my car is sitting. There is a pretty good down angle on the bars and I have concerns about the car going straight on the launch. See attachment
Re: Ladder Bar Question [Re: moparmanjames] #513888
11/02/09 02:00 AM
11/02/09 02:00 AM
If there is only one set of mounting holes I would not be buying that set up
Re: Ladder Bar Question [Re: Cab_Burge] #513889
11/02/09 02:04 AM
11/02/09 02:04 AM
Las Vegas NV
Las Vegas NV
I already bought it, that pic is as installed in the car, I'm should have them take it off and go with a 4 link eh?
Re: Ladder Bar Question [Re: moparmanjames] #513890
11/02/09 02:12 AM
11/02/09 02:12 AM
I don't want to rain on your project but I see a lot of required parts of the cage missing, hopefully there not representing this back half picture as all that is needed, are they? Is the rear suspension in and is the car at ride hieght or cloes to it in your picture? I really don't like the way the ladder bar mounts are on the rear end and where they mounted them in relation to the frame rails
Re: Ladder Bar Question [Re: Cab_Burge] #513891
11/02/09 02:30 AM
11/02/09 02:30 AM
Las Vegas NV
Las Vegas NV
It's very close to it in the sig picture. The cage was not complete at the time but is almost complete now. My main question was the angle of the ladder bars. That was the only picture I had available to show of the angle.
The car is still at the shop. Here is a better pic of the cage coming along
Re: Ladder Bar Question [Re: moparmanjames] #513892
11/02/09 02:32 AM
11/02/09 02:32 AM
Las Vegas NV
Las Vegas NV
another
Re: Ladder Bar Question [Re: moparmanjames] #513893
11/02/09 02:51 AM
11/02/09 02:51 AM
That looks a lot better, see if they will fix it for free before offering to pay for the switch to a four link If they can't insatll a ladder bar correctly how many ways can they mess up a four link installation You don't want the car to hurt you or drive you broke trying to make it go straight and easy to drive, does this shop have a good reputation with a lot of cars out there working really good? If not think about switching for the last changes to the rear suspension, let them learn on someone else
Re: Ladder Bar Question [Re: moparmanjames] #513894
11/02/09 06:23 AM
11/02/09 06:23 AM
Q
Quicktree Offline
Quicktree  Offline
Q
that door bar looks high, are they raising the seat? looks like it will be higher than your shoulder?
Re: Ladder Bar Question [Re: Cab_Burge] #513895
11/02/09 10:12 AM
11/02/09 10:12 AM
Las Vegas NV
Las Vegas NV
They have a good reputation with circle track cars, but I think since this back half was a bargain deal they tried to use the parts that were there instead of telling me I had to buy different brackets. They are very knowledgable about the front suspension but they don't seem so much so on the rear of a drag racer.
Re: Ladder Bar Question [Re: moparmanjames] #513896
11/02/09 10:16 AM
11/02/09 10:16 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
the ladder bar needs to be level to the ground now and adjustment holes up and down for tuning.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Ladder Bar Question [Re: bigtimeauto] #513897
11/02/09 10:19 AM
11/02/09 10:19 AM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
One more thing. The way the cage is built it will not cert lower than 8.50
Re: Ladder Bar Question [Re: Quicktree] #513898
11/02/09 10:20 AM
11/02/09 10:20 AM
Las Vegas NV
Las Vegas NV
No it's ok, although I might raise it a little for better vision.
Re: Ladder Bar Question [Re: bigtimeauto] #513899
11/02/09 10:22 AM
11/02/09 10:22 AM
Las Vegas NV
Las Vegas NV
Yeah they arent finished with the cage but what are you seeing? Every little bit helps, thanks.
Re: Ladder Bar Question [Re: moparmanjames] #513900
11/02/09 10:28 AM
11/02/09 10:28 AM
ky
68roadrunner Offline
ky
i am no chassis expert, but that will not work.
the ladder bar crossmember dictates the ride height of the car. the bottom ladder bar should be level with the ground in the middle hole of the cross member bracket, then install shock to hold car at that heigth. that is the way it was explained to me when i put them in my roadrunner.
i could be all wrong here, maybe a real chassis guy will chime in.
Re: Ladder Bar Question [Re: bigtimeauto] #513901
11/02/09 10:34 AM
11/02/09 10:34 AM
Las Vegas NV
Las Vegas NV
"the ladder bar needs to be level to the ground now and adjustment holes up and down for tuning."
Yeah that's what I thought too, so seeing as how the car is so low, how would you fix it? I think the axle brackets have to be re-welded and moved inboard and different front brackets made.
Here's a pic and you can barely see it but it's on the right side where the ladder bar mounts to the front.
Re: Ladder Bar Question [Re: moparmanjames] #513902
11/02/09 10:50 AM
11/02/09 10:50 AM
ky
ky
yep! move the axle brackets inside of the frame rails, build (or buy)a cross member with 5 or 6 holes for adjustment. mounted between frame rails at the proper height so the car will set that low. from the looks of the frame rails there will need some creative work there to get the cross member that high.
Re: Ladder Bar Question [Re: 68roadrunner] #513903
11/02/09 11:46 AM
11/02/09 11:46 AM
Las Vegas NV
Las Vegas NV
Yeah the car is lowered so much I'm going to have to get silly with it. Since the axle is higher than the frame, maybe I can use a longer lower bracket on the axle to get it level with the ground.
Re: Ladder Bar Question [Re: moparmanjames] #513904
11/02/09 12:37 PM
11/02/09 12:37 PM
ky
ky
have never seen an offset bracket to lower the bars lower on the axle. i would be afraid that would change the leverage on the chassis. if it did, any normal tuning info would be out the window.
Re: Ladder Bar Question [Re: 68roadrunner] #513905
11/02/09 12:56 PM
11/02/09 12:56 PM
Las Vegas NV
Las Vegas NV
Ok then I guess I'll go the other rout lol, I don't want to start screwing things up worse.
Re: Ladder Bar Question [Re: moparmanjames] #513906
11/02/09 02:58 PM
11/02/09 02:58 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
UH...that thing will NEVER launch with the ladder bar at that angle. I'm sorry but your going to be battling a HUGE issue.The bottom bar of the ladder bar needs to be as close to parallel to the ground as possible in order for it to work.Where you have it now the car will only spin on the launch.Build whatever it takes to get the bar level. I'll look at the other pics and see what else can or needs to be corrected. I see some Chassisworks tin in there did you purchase it from them?
