Re: exploded 8 1/4 SureGrip view? [Re: MonGoo$e] #512763
11/01/09 08:34 PM
11/01/09 08:34 PM
Indiana
MonGoo$e Offline OP
MonGoo$e  Offline OP
Indiana
And on another note, i set 2 of my open carriers up side by side with the SG unit and the ring flange on all 3 are different heights. the SG being about 1/4" difference from the one that came of of the housing I'm using.
Hmm..
My YouTube Channel, "Hoosier Garage"
https://www.youtube.com/HoosierGarage
Re: exploded 8 1/4 SureGrip view? [Re: MonGoo$e] #512764
11/01/09 09:51 PM
11/01/09 09:51 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Post a pic of them side by side. Should only be two sizes IIRC. When you get into the 4.10 ratios and above the pin will need to be a notched one to get it past the ring gear.
Re: exploded 8 1/4 SureGrip view? [Re: mopars4ever] #512765
11/01/09 10:30 PM
11/01/09 10:30 PM
Indiana
MonGoo$e Offline OP
MonGoo$e  Offline OP
Indiana
Here are all 3 that I have. all are sitting flat on the bearing snouts, not at all on the bearings.
Between the SG unit and the open 2.71 unit that came in the housing I am using, there is 7/16" difference exactly.
Between the 2.71 open and the later model unit I have, there is 1/16" difference.
When I got the later model, it had the 3.55 gear you see on the SG on it, i bought it from a dealer tech who said he had it in the rear of his 73 Dart. I know for sure that 3.55 will not fit on that 2.71 open carrier because I tried to test fit it..no dice. picture attached
Re: exploded 8 1/4 SureGrip view? [Re: MonGoo$e] #512766
11/01/09 10:31 PM
11/01/09 10:31 PM
Indiana
MonGoo$e Offline OP
MonGoo$e  Offline OP
Indiana
all 3
Re: exploded 8 1/4 SureGrip view? [Re: MonGoo$e] #512767
11/01/09 10:33 PM
11/01/09 10:33 PM
Indiana
MonGoo$e Offline OP
MonGoo$e  Offline OP
Indiana
the 3.55 is a bit thicker than the 2.71 so I'm wondering if the difference is offset with that in mind. But I hear of people getting a 2.45 SG carrier and having to use a spacer..which seems, backwards to me judging by what I have here, and the fact gears are thicker as they get numerically higher
Re: exploded 8 1/4 SureGrip view? [Re: MonGoo$e] #512768
11/01/09 10:37 PM
11/01/09 10:37 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I may be wrong but it appears that the sure grip carrier you have is the 2.45 ratio one. Someone correct me if i`m wrong.
Re: exploded 8 1/4 SureGrip view? [Re: mopars4ever] #512769
11/01/09 10:49 PM
11/01/09 10:49 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
Re: exploded 8 1/4 SureGrip view? [Re: 500ciDuster] #512770
11/01/09 10:55 PM
11/01/09 10:55 PM
Indiana
MonGoo$e Offline OP
MonGoo$e  Offline OP
Indiana
You all maybe right, I typed in that part number on the diff on Google and found this post:
http://www.forabodiesonly.com/mopar/showthread.php?p=672610
Looks like I wasted my cash on something useless. Who'd run a 2.45 SG these days?
Re: exploded 8 1/4 SureGrip view? [Re: MonGoo$e] #512771
11/02/09 12:08 AM
11/02/09 12:08 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Yeah most guys throw those away, me on the other hand I would love to find one for my dakota Get both tires turning in the snow and blow off some tq and lower the highway rpms too.
Re: exploded 8 1/4 SureGrip view? [Re: HotRodDave] #512772
11/02/09 12:12 AM
11/02/09 12:12 AM
Indiana
MonGoo$e Offline OP
MonGoo$e  Offline OP
Indiana
if you want it MSG me.
