Zinc Oxide Primer vs. Red Oxide Primer #511580
10/30/09 02:06 PM
10/30/09 02:06 PM
Renton, Washington
Bobster Offline OP
Bobster  Offline OP
Renton, Washington
Hey everyone.
Finally getting to work on the body of my Challenger and I decided to work on the taillight assembly panels.
Just got done stripping them down and noticed that they used red oxide primer. I was going to use a gray zinc oxide primer. Since this is my first time working on body work I figured I'd ask you guys and gals out there.
My question is this: What would be best to use? Would the corrosion benefits of gray primer be better than the exposure benefits of red primer?
Thanks for all the help!
Re: Zinc Oxide Primer vs. Red Oxide Primer [Re: Bobster] #511581
10/30/09 02:26 PM
10/30/09 02:26 PM
Renton, Washington
Bobster Offline OP
Bobster  Offline OP
Renton, Washington
Forgot to mention, the taillight panel is of the 1972-74 kind. Going to be using silver argent on it.
Re: Zinc Oxide Primer vs. Red Oxide Primer [Re: Bobster] #511582
10/30/09 04:00 PM
10/30/09 04:00 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Here's a bump, but the correct answer I believe is not one of the above, I would think an etching or a 2 part epoxy primer would be a better choice.
Re: Zinc Oxide Primer vs. Red Oxide Primer [Re: jcc] #511583
10/30/09 04:11 PM
10/30/09 04:11 PM
Renton, Washington
Bobster Offline OP
Bobster  Offline OP
Renton, Washington
That's what I was leaning towards. Thanks!
