4 speed A833 Question #510804
10/29/09 04:17 PM
10/29/09 04:17 PM
Denmark, Helsingor
AAR70 Offline OP
AAR70  Offline OP
Denmark, Helsingor
Will a very worn gears in a gearbox A833 generate much noise or high vibrations?
Re: 4 speed A833 Question [Re: AAR70] #510805
10/29/09 07:10 PM
10/29/09 07:10 PM
LEE, MASS
TOMRR Online content
TOMRR  Online Content
LEE, MASS
http://www.passonperformance.com/
Re: 4 speed A833 Question [Re: TOMRR] #510806
10/29/09 08:12 PM
10/29/09 08:12 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
well mine is whining on second gear,its like having a little compressor between the seats.no vibration though,yet
Re: 4 speed A833 Question [Re: AAR70] #510807
10/29/09 10:00 PM
10/29/09 10:00 PM
Richland , Webster County,Ga
Bubba C Offline
Bubba C  Offline
Sounds like a bearing problem some where..In the rear, or tranny. Or..is your engine internal or external balanced? And did you run the correct flywheel?
Bubba
Re: 4 speed A833 Question [Re: Bubba C] #510808
10/30/09 05:58 PM
10/30/09 05:58 PM
Denmark, Helsingor
AAR70 Offline OP
AAR70  Offline OP
Denmark, Helsingor
There is`nt High vibration in neutral ,only at speed between 90-120 mph in 3th and 4th gears.
I have only notice small vibratins at 2000rpm in neutral, no noise.
How much play/backlash can I measure If I turn the A833 outputshaft with yoke clockwise and anticlockwise ?
Re: 4 speed A833 Question [Re: AAR70] #510809
10/31/09 12:04 AM
10/31/09 12:04 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
like someone said call passon. great people to deal with and he'll go over anything and everything you wanna go over. it isn't too hard to rebuild these either. i see you're overseas so maybe e-mail him if its crazy money to call . i've rebuilt my 23 spline and my dad's 18 spline. just get a factory service manual and look up the mopar muscle issue with it in there. basically it sounds like you need somehting new in there and you might as well replace most of it. good luck
