Re: what stops the cig lighter from being a dead short?
[Re: Andrewh]
#510277
10/28/09 08:08 PM
10/28/09 08:08 PM
RapidRobert
it doesn't make (electrical) contact until you push it in all the way. When the element becomes cherry red it pops back a bit & breaks contact. Except for the controlled resistance in the heating coil it actually is pretty much a dead short for a few seconds until the element heats up & it breaks contact
[Re: Andrewh]
#510278
10/28/09 08:09 PM
10/28/09 08:09 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
Might be obvious when I pull it out. But I want to wire mine up again in my coronet.
Is there some isolator that wears out or how it mounts?
I think what he means is why does the positve not just short straight to the negative, even without the element in.
Yes, there is an insulator that supports the center contact, and keeps it from contacting the outer housing. I think it's porcelyn. I think they break and fall out after a while.
Contact is made through the lighter element itself, which (as mentioned) has a resistance to it.
