Page 1 of 4 1 2 3 4
clogged idle air bleed (update)!!!! #510064
10/28/09 05:37 PM
10/28/09 05:37 PM
Q
Quicktree Offline OP
Q
what will a clogged idle air bleed do?
A. make the idle circuit rich
B. stop the fuel to the idle circuit
Re: clogged idle air bleed [Re: Quicktree] #510065
10/28/09 05:41 PM
10/28/09 05:41 PM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline
VanishPt  Offline
V
Re: clogged idle air bleed [Re: VanishPt] #510066
10/28/09 05:52 PM
10/28/09 05:52 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
All it controls is air...you know this Tony, this a trick question?..
Re: clogged idle air bleed [Re: Bob_Coomer] #510067
10/28/09 05:57 PM
10/28/09 05:57 PM
Q
Q
no
Re: clogged idle air bleed [Re: Quicktree] #510068
10/28/09 06:06 PM
10/28/09 06:06 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
should do both..the air being pull though the air bleed pull fuel out also. no air flow ,no fuel flow
Post deleted by Defbob [Re: Quicktree] #510069
10/28/09 06:06 PM
10/28/09 06:06 PM
Re: clogged idle air bleed #510070
10/28/09 06:21 PM
10/28/09 06:21 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
The smaller the bleed the richer the circut, the larger the bleed the leaner the circut,, in my opinion if one is plugged it will go dead rich.
Re: clogged idle air bleed [Re: dartman366] #510071
10/28/09 06:22 PM
10/28/09 06:22 PM
Q
Q
how would it pull fuel with no air?
Re: clogged idle air bleed [Re: Quicktree] #510072
10/28/09 06:28 PM
10/28/09 06:28 PM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
The idle passage is a slot just below the throttle plates when closed. Engine vacuum pulls fuel through the idle fuel restriction then the air bleed mixes air. The air bleed will mix air with the fuel so it is not "solid". Same with the hi speed bleed with fuel being pulled up the main well.
Re: clogged idle air bleed [Re: AAR-B4] #510073
10/28/09 06:30 PM
10/28/09 06:30 PM
Q
Q
so your saying it will pull fuel reguardless if the bleed is clogged or not?
Re: clogged idle air bleed [Re: Quicktree] #510074
10/28/09 06:33 PM
10/28/09 06:33 PM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
Yes, but it will not be pre-mixed with air. It will idle rich.
Re: clogged idle air bleed [Re: AAR-B4] #510075
10/28/09 06:35 PM
10/28/09 06:35 PM
Q
Q
well I am running into just the oppisite problem. it is way lean on tip in and I found 2 rear bleeds completely clogged.
Re: clogged idle air bleed [Re: Quicktree] #510076
10/28/09 06:38 PM
10/28/09 06:38 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
The venture still is operational, it dont care if there is another hole or not..The Restriction speeds the air up threw the venture cause a low pressure area in "said area"
Coarse Im no guru.
In other words the air, and fuel idle or high speed circuits are just that diff circuits.
Re: clogged idle air bleed [Re: Quicktree] #510077
10/28/09 06:39 PM
10/28/09 06:39 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Yep. Carbs work on differences in pressure. The air pressure on the top of the fuel is higher than the pressure (vacuum) below the throttle plates. This will pull fuel into the motor through the idle circuit when running.
The main circuit outlet is in the venturi, so it needs the air bleed to stop the flow. Otherwise, it will siphon all the time after the first flow is started, if the outlet is lower than the fuel level in the bowl.
Re: clogged idle air bleed [Re: Quicktree] #510078
10/28/09 06:40 PM
10/28/09 06:40 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
The bleed is to air as the jet is to fuel, as bleed size is increased the air fuel ratio become's leaner, as the bleed is decreased it become's richer , so if it were plugged it would pull pure fuel as opposed to air emulsed fuel.
Re: clogged idle air bleed [Re: Quicktree] #510079
10/28/09 06:44 PM
10/28/09 06:44 PM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
The idle bleeds are towards the outside, the hi speed are close to the squirter. The idles' should have a larger hole than the hi speed.
Re: clogged idle air bleed [Re: Quicktree] #510080
10/28/09 06:47 PM
10/28/09 06:47 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
http://www.carcraft.com/howto/ccrp_0507_carb_tuning_tips_tricks/photo_12.html
Tip in is
1. Idle circuit. If this is fine at idle, this is not the cause.
2. Transfer port. This is checked by holding the throttle open slightly (idle + 200 RPM) to see if it's lean there. Most 70s-up stock carbs are a bit lean here.
3. Accelerator circuit. This will show up at any RPM, but be more noticable at low RPM. Do you have issues at say 30 MPH?
4. Main circuit. This should start to work at ~1400 RPM. You can see this by looking down the throat. WARNING! lean pop may catch you in the face!
5. Power circuit. When it's a quick tip in, the vacuum drops enough to open the power circuit. If it is needed but does not work, this will also be a flat spot.
Re: clogged idle air bleed [Re: RodStRace] #510081
10/28/09 06:55 PM
10/28/09 06:55 PM
Q
Q
Tip in is
this is a 3 circuit dominator I am talking about.
http://holley.com/data/Products/Technical/199R9786-2.pdf
Re: clogged idle air bleed [Re: Quicktree] #510082
10/28/09 07:22 PM
10/28/09 07:22 PM
Q
Q
interesting topic, does anybody know what stock air bleeds comes on a 8896-2 dominator? I cant find it on holley's site
Re: clogged idle air bleed [Re: Quicktree] #510083
10/29/09 05:47 AM
10/29/09 05:47 AM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
it will still flow fuel and it will be rich'er' at certain flow-rates...
Page 1 of 4 1 2 3 4
