318 poly intake bolts #509611
10/28/09 12:56 AM
10/28/09 12:56 AM
Hannibal, MO
gtx_gts1969 Offline OP
super gas
super gas
Hannibal, MO
Do any of the intake bolts go into water jackets? Thanks in advance!
-------------------------------------------- 1966 Dodge D100 short wide bed / 318 / 3spd Retired US Air Force MSgt (E-7)
Re: 318 poly intake bolts [Re: gtx_gts1969] #509612
10/28/09 01:57 PM
10/28/09 01:57 PM
Andrewh Offline
Andrewh  Offline
I want to say no, but I am not positive.
I usually have the block mostly empty pulling the intake so I can't say for sure, but I don't remember any.
Re: 318 poly intake bolts [Re: Andrewh] #509613
10/29/09 03:17 AM
10/29/09 03:17 AM
Hannibal, MO
super gas
super gas
Hannibal, MO
Thanks! So if they don't go into water jackets, what does it mean when I have anti-freeze leaking at some of the intake bolts?
Re: 318 poly intake bolts [Re: gtx_gts1969] #509614
10/29/09 03:56 AM
10/29/09 03:56 AM
they either go into the water jackets or coolant is bleeding over from a nearby water port
Re: 318 poly intake bolts [Re: gtx_gts1969] #509615
10/29/09 09:21 AM
10/29/09 09:21 AM
Andrewh Offline
Andrewh  Offline
Water does flow through part of the intake, so I would check the gasket there, or see if there is a crack somewhere.
I really don't remember ever seeing coolant in a bolt hole for the intake.
Re: 318 poly intake bolts [Re: Andrewh] #509616
10/29/09 01:41 PM
10/29/09 01:41 PM
Hannibal, MO
super gas
super gas
Hannibal, MO
Thanks!
Re: 318 poly intake bolts [Re: gtx_gts1969] #509617
10/29/09 05:44 PM
10/29/09 05:44 PM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
gotta be bleeding thru from one of the coolant ports.
Just pulled a intake off a original, unmolested 50K mile 318 poly due to a bent pushrod - no sealer on any of the bolts.
When I assembled it I put a light bead of silicone around each coolant port as insurance.
Driven about 1K miles and bolts are dry.
Re: 318 poly intake bolts [Re: SSAAHemiFan] #509618
10/30/09 03:33 AM
10/30/09 03:33 AM
Hannibal, MO
super gas
super gas
Hannibal, MO
Thanks for the feedback! More info, I have the wieand aluminum 4bbl intake and it has been on the motor at least 8-10 months before the seeping started.
Re: 318 poly intake bolts [Re: gtx_gts1969] #509619
11/01/09 01:09 PM
11/01/09 01:09 PM
Hannibal, MO
super gas
super gas
Hannibal, MO
Re: 318 poly intake bolts [Re: gtx_gts1969] #509620
11/01/09 01:54 PM
11/01/09 01:54 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Have you tried snugging up the bolts?
If you re do gaskets (drain water down first) put a liberal smear of silicone on both sides of gasket.
some on any bolt you suspect of going into water.
lightly tighten then wait 2 hours snug real good leave over night then tighten good. Tighten again after heat cycle then again when cooled right down.
tighten again in a week and check periodically!
I love them little poly's!! LOL!
