361 build up #503651
10/22/09 11:28 AM
10/22/09 11:28 AM
Temecula, Ca.
Z
zzyzxpat Offline OP
zzyzxpat  Offline OP
Z
Temecula, Ca.
I wanted to get advise from the gurus here on my project. I am building a 361 because it is the original engine on a completely original '66 Coronet. I am using 516 heads, with 1.74 exhaust. Pistons will have to be custom since they are no longer made. I am going zero deck, with .038 gasket, and should be about 9.5-10.0 to 1 comp. I was thinking of putting a 440 crank in it to gain some CID. This will be used primarily on the street. I would also like a cam recommendation.I was thinking a Comp XE 292. What do you folks think? Thank you, Pat
" The last official act of any goverment, is to loot the treasury" George Washington
Re: 361 build up [Re: zzyzxpat] #503652
10/22/09 12:13 PM
10/22/09 12:13 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
not to be mean, but it sounds like a waste of time and money to me. custom pistons will be expensive. adding a 440 crank will be expensive (custom pistons, plus having the mains and counterweights turned down) to essentially get you a low deck 413. why not just start with a 440 and use some KB flat tops? it'll be cheaper in the long run, and you'll still be 25 cubes over your stroker motor. I'd just put the engine under a workbench all wrapped up if you ever want to return it to stock.
for a street car, don't go too big on cam. I'd probably look at something like an XE275HL. if your heads need to be rebuilt, I'd strongly look at just getting some aftermarket aluminum heads, OOTB they flow as well as well ported factory iron heads, and aren't much more expensive than redone stock heads with new valves, springs, keepers, retainers, seals, and machine work.
2017 Grand Cherokee Overland
Re: 361 build up [Re: patrick] #503653
10/22/09 12:23 PM
10/22/09 12:23 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Yeah its expensive to do a 361 but they are screamers.I had quite a few.The one that was in my 65 I tried to blow.The old man wouldnt let me put a 440 in unless the 361 went south.I floated the valves so many times I cant remember.Never did scatter it.Man that was a long time ago like 40 years.Rocky
Chrysler Firepower
Re: 361 build up [Re: patrick] #503654
10/22/09 12:56 PM
10/22/09 12:56 PM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
Unless you're just dead set on using the original engine, it won't hurt to stash it away if you ever want to return it to stock. It will also be much cheaper and less hassle. The other thing to think about is that if the worst thing happens (like a rod making an emergency exit) it's better to trash an easier to come by 440 than your original 361.
Re: 361 build up [Re: Reggie] #503655
10/23/09 01:23 AM
10/23/09 01:23 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Do you plan to race it any at all ? Ron
Re: 361 build up [Re: 383man] #503656
10/23/09 01:32 AM
10/23/09 01:32 AM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
If you're attached to the original block at all.... Take my advice! Buy a block, AND a cart, then shove the 361 under the bench! I made a mistake of building my "numbers" block... NEVER again! NEVER! It shifted in the maching during boring and then required a sleeve! the pad numbers were milled off! (again) and it DOESN'T make near the power that a 400+ stroker build or even a 440 build COULD'VE made!!!! for LESS! find another block and have at it! You will sleep better and have a better build in the end
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: 361 build up [Re: zzyzxpat] #503657
10/23/09 01:53 AM
10/23/09 01:53 AM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
If you are sure you want to use the original block here is my recipe.Do not stroke the engine.Forget the 516's.New pistons 9.5 to 1.A set of 915's with the 2.08 and 1.75 exh valves (doesn't need big valves) w/bowl job and port match.Performer RPM with a 750 of your choice.Lunati 60303 and 1 7/8 headers.Should make 1+ h.p per cubic inch and have some great torque too. Enough engine to run in the 12's and won't break the bank either.
Leave the gun.......take the Cannoli's....Mike
Re: 361 build up [Re: zzyzxpat] #503658
10/23/09 08:30 AM
10/23/09 08:30 AM
Temecula, Ca.
Z
zzyzxpat Offline OP
zzyzxpat  Offline OP
Z
Temecula, Ca.
Thanks for all the advise guys. I completely understand what you are saying, both from the cost of building a 361 and in keeping the original block safe. This gives me alot to think about. Pat
