Quench vs. C/R vs. Fuel octaine
#502160
10/20/09 04:23 PM
10/20/09 04:23 PM
Posts: 1,101 Retired now in Tennessee
Chi_Town_Runner
I'm in the porocess of building a 383/438 stroker. On the KB calculator my computations come out as follows Heads = 84cc Piston Head volume = 4(valve reliefs on flat top pistons) Gasket Thickness = .029 Gasket Bore -= 4.350 Cylinder Bore = 4.310 Deck clearance = .010 Stroke = 3.750 Computes to STATIC compression of 10.203 adding rod length = 6.760 Valve timing @ 6* Intake closing point = 38* Dynamic CR = 9.472 I am trying to keep the quench at .040 so if I were to use a head gasket of .039 I would have the block decked for 0 deck clearance. Will this run on the 91 octain I have available to me. If not what do I need to do to keep the quench but lower compression (if I have too)? Thanks Frank
Remember - 2 wrongs don't make a right - but 3 rights make a left!
Re: Quench vs. C/R vs. Fuel octaine
[Re: Chi_Town_Runner]
#502161
10/20/09 06:56 PM
10/20/09 06:56 PM
RapidRobert
With those numbers I believe so and I'd make sure of all my measurements to get em exactly where I want them. If you go w full floating pins you can mock everything up, measure & easily pull the pistons to machine them for an exact zero deck height to go with your .039" gaskets. If needed you can enlarge/polish the chamber(s) with your porting burrs/tootsie rolls. Doesn't take much material to be removed.
[Re: dynorad]
#502163
10/20/09 07:37 PM
10/20/09 07:37 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
as it calculated, no. But I think your number for the intake valve closure is off. What cam is it? You need the spec for .050 lift... not .005 or .006 lift....
[Re: moper]
#502164
10/20/09 07:54 PM
10/20/09 07:54 PM
Chi_Town_Runner
They are full floating pins, The cam (not yet purchased) is Comp Cams XR274HR-10 Hydraulic Roller (let the solid guys begin ) Duration I/E = 274/282 Duration I/E @ .50 = 224/230 Lift I/E = .538/.534 More thoughts Frank
[Re: 64Post]
#502170
10/20/09 09:57 PM
10/20/09 09:57 PM
Chi_Town_Runner
Thanks, Quote:
At 6000' emphasis should be placed on cylinder pressures, otherwise you'll end up with a dog of a motor.
But now how to alter or adjust cylinder pressure without effecting C/R or can't you?
[Re: RapidRobert]
#502173
10/20/09 11:13 PM
10/20/09 11:13 PM
Chi_Town_Runner
The cam has not yet been purchased. I'm taking the block to the machinist on Thursday so at this point I can make any adjustments with no downside. Thanks Frank
#502174
10/21/09 08:15 AM
10/21/09 08:15 AM
Posts: 74,974 U.S.S.A.
JohnRR
U.S.S.A.
Frank , what heads , iron or alum ? Closed chamber or open ? As far as machining each piston for perfect quench ... first off that's , second , it's impossible unless he had A CUSTOM piston made because a quench head piston for a 383 stroker DOES NOT EXIST , so if it's the custom the last thing I would be doing is cobbling up a $1000 set of pistons.
[Re: JohnRR]
#502175
10/21/09 09:04 AM
10/21/09 09:04 AM
moper
Columbia, CT
Like John said... easier to get tthe machining right then individually fit each piston..
I agree at 6000' you want more squeeze... I confess I'm a sea level guy so how much is too much I am not sure. I do know Comp doesnt publish the intake closing event but you should be able to get it from them by phone if you ask.
[Re: JohnRR]
#502176
10/21/09 09:49 AM
10/21/09 09:49 AM
Chi_Town_Runner
Heads 440source stealth 84 cc Pistons are flat top with 2 valve reliefs Compression height 1.320" Thanks for any additional input. I'll be on the phone today to Comp re specs. As I said, the cam has not been purchase yet so I have flexability with that. Any thought on that? I may post a new thread re: cam selection. Frank
[Re: moper]
#502178
10/21/09 11:13 AM
10/21/09 11:13 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
my cam is a little [Email]259@.006[/Email], [Email]208@.050[/Email] hydraulic roller, 112LSA installed at 108, and my intake close point, going by .006" lift advertised is ~57.5 degrees ABDC.... 0.50 duration is 32 degrees ABDC....mine is a 318, 9:1 measured, no quench (.083" quench distance), and runs on 87 octane.
I'm guessing the number you really need to use to determine DCR is going to be closer to 60 deg. ABDC....
EDIT, seeing the cam you choice, 274 .006 intake duration (what comp uses for "advertised duration"), if installed at 106 ICL, would net you an intake close point 63 degrees ABDC, not 38. the KB calculator says to use .050 ICP+15 degrees, which nets 53 deg. ABDC. using .006 numbers you get 8.2 DCR, using the KB method nets 8.8....it should run fine on 92 or 93, you may have to be a little conservative with your distributor's timing curve.
