No Heat #499347
10/17/09 11:04 AM
10/17/09 11:04 AM
Anonymous OP
Anonymous OP
97 Ram 2500 I have no heat I flushed the system but that did nothing..whats next??
Re: No Heat #499348
10/17/09 01:08 PM
10/17/09 01:08 PM
I dont know the late stuff but I would find the valve (vacuum or cable controlled) that controls the coolant flow & see if it's open or shut. then if the right doors are open/closed to direct air thru the heater core.
Re: No Heat [Re: RapidRobert] #499349
10/17/09 01:13 PM
10/17/09 01:13 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Seems that the diverter door has been a problem for a lot of pepolpe here. You'd do better asking on the truck forum here.
